synthetic or not
Old 04-05-11, 03:34 PM
slidingIS
slidingIS's Avatar
Synthetic oil lasts much longer and doesnt break down as easily. it also doesnt leave any buildup. non-synthetic oil is just plain cheap. i cant believe the Lexus dealership even offers an oil change using non-synthetic oil
Old 04-05-11, 04:08 PM
ISSteve
ISSteve's Avatar
Not just offers, RECOMMENDS non-synthetic. My dealer flat out told me it's not worth the extra expense as long as you are getting the oil changed at the recommended intervals. Good enough for me.
Old 04-05-11, 04:24 PM
slidingIS
slidingIS's Avatar
wow i wonder why this is. Im gonna call Lexus tomorrow and see if i can get some more info on this
Old 04-05-11, 04:31 PM
svntwosix
svntwosix's Avatar
Read this thread.
https://www.clublexus.com/forums/is-...s-results.html
My recommendation: if you choose to always go to the dealership at 5k miles, just stick with non-synthetic. If you choose to do 1 year changes with 10k+ miles, go with synthetic.
Money is money, no point in paying for a premium you would never get the benefit from.
Old 04-05-11, 04:37 PM
llamaboiz
llamaboiz's Avatar
fyi: Castrol = British Petroleum, am i trying to say something? you decide.
Old 04-05-11, 05:47 PM
IS-SV
IS-SV's Avatar
Mobil 1 synthetic only for me at once 10K miles max intervals or once per year whatever comes first. My Lexus dealers stocks it and has no problems using it in my IS350.
Old 04-05-11, 06:00 PM
dapimpee
dapimpee's Avatar
my mechanic friend always recommends me syn.
Old 04-05-11, 08:33 PM
Phresh2010
Phresh2010's Avatar
20 bucks per oil change + filter using valvoline full syn (a friend works at GM and hooks it up!)
use to use mobil 1 full syn until i got this hook up, so much cheaper
Old 04-05-11, 08:40 PM
Sffd103
Fire Slayer
Sffd103's Avatar
I found Mobil 1 Synthetic case of 6 at Costco for $35. You can order the filter from Sewell for cheap. Just buy one more quart elsewhere and you can roll in to the Toyota dealer for the cheapest price.
Old 04-05-11, 08:59 PM
CleverName
CleverName's Avatar
Going Synth at 40k is probably just fine, however I seldom recommend switching to it above the 50 mark, and especially not if the car has been poorly maintained with infrequent oil changes prior to the switch. There are definite issues that can arise when changing to synth if you are not the original owner or lax on the regular oil change intervals.
As other have attested, synth is really not required for a normally aspirated engine, but if it makes you feel better, it certainly does no harm to trust it.
I'm old school in most things, and will continue to use standard oils changed regularly at 3000 mile intervals. That rule will never do you wrong.
For my turbo bikes and cars, where oil must function in a glowing turbo housing, I will run only Mobil1, and even there I travel no more that 3k change.
Vince
Old 04-05-11, 09:08 PM
RCB
RCB's Avatar
10k oil changes are just scary to me. I can't bring myself to wait longer then 3,500 miles. I run mobil 1 0/5w30 depending on season is my IS250.
I use valvoline VR1 20w50 in the supra and I'm thinking about switching to Enos 0-50 this year.
Old 04-05-11, 09:13 PM
birador
birador's Avatar
if you drive your car on hi-way which usually gets you an oil change before its reach the due date on sticker,its very reasonable to use the non syntec but if you are the type of driver that keep the car almost on garage,syntec is good option.
Old 04-05-11, 09:23 PM
GSteg
GSteg's Avatar
The interval matters more than the oil itself. Any API approved oil is good enough for your engine. Many are led to believe that if you're not running synthetic oil, your engine will not make it past 200k miles or some other nonsense. Properly maintained engine, whether it be with dino or synthetic, is the key. If you want to be sure, get a used oil analysis and see how good the wear is with conventional oil. I'm willing to bet engine wear will still be good, and that your car will die of other cause long before the engine wears itself out.
Also, many people run synthetic oil for longer intervals, but they neglect the fact that the filter needs to be changed too. One (popular) viable method is to change out your filter but don't drain the synthetic fluid. Simple replace the filter and then top off your engine oil. That way you get fresh filtration while making of the (still) good motor oil.
If your car sees more extreme conditions, then synthetic oil may be more appropriate.
Old 04-05-11, 10:36 PM
RRocket
RRocket's Avatar
Amsoil 0W20 here....
Old 04-05-11, 10:40 PM
Joey-E
Joey-E's Avatar
Synthetic all the way!
Quick Reply: synthetic or not
