Blown Side Mirror Puddle Lights?
Old 02-03-11, 02:03 AM
yungsters
yungsters's Avatar
Default Blown Side Mirror Puddle Lights?
Tonight I realized that as I approach my car, the interior front and rear domes light up, but the side mirror puddles do not. I remember they used to, but I don't know when they stopped working.
Any ideas? Is it likely that both sides' light bulbs are blown? If so, I am considering swapping them out for LEDs.
Old 02-03-11, 03:21 AM
vinconist
vinconist's Avatar
ya either its a blown fuse or its both lights are out, go take out the fuse and check it out, u can tell its blown or not, look in ur manual for the location
Old 02-03-11, 03:45 PM
brociouz
brociouz's Avatar
If both bulbs are indeed blown, I recommend: http://www.v-leds.com/Interior-LED/D...68086-1-3.html (they have 5000K, blue and other colors as well).
Old 02-03-11, 08:23 PM
yungsters
yungsters's Avatar
I ordered a pair of the 6Ks that you linked (to match my low beams). Thanks for all the answers!
Old 02-08-11, 01:37 AM
yungsters
yungsters's Avatar
I got my 6K LEDs today and installed both of them. However, they still did not light up. I checked all the colorful fuses and they seemed to be fine. Any other ideas? Did I check the wrong fuses?
Old 02-08-11, 05:32 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Sometimes when installing Led's you need to turn the bulb around if they don't light up. Wish you would have checked it before you closed it all up. You'll have to open it all up again.
Old 02-08-11, 09:38 AM
Cali2is
Cali2is's Avatar
with those leds... after you install them you need to pull them out a little bit. Not sure why, but that worked for me.
Old 02-08-11, 10:00 AM
yungsters
yungsters's Avatar
I had read about having to pull it out, so I tried that, too. Neither side worked. Also, I think the VLEDs work both directions. I could be wrong... :[
I've scheduled a diagnostic with a dealership and will go try an autoshop before then. Thanks for all the feedback!
Old 02-20-11, 04:10 PM
yungsters
yungsters's Avatar
So after I brought my car to the dealership, I learned that the side mirror puddle lights can be turned off! /facepalm
I'm not sure when or how mine were turned off, but it does not matter now. When he showed me that they working, I saw the full glory of my 6K LEDs. They look sooo good!
They fixed it for free (but my car also had a bunch of other things that needed to be fixed, see this thread).
Leechmon
03-25-18 05:25 PM
caverman
04-12-17 08:50 PM
TriniLex
ES - 5th Gen (2007-2012)
11-06-15 06:45 AM
galump
02-07-11 08:07 PM
Quick Reply: Blown Side Mirror Puddle Lights?
