Old 01-09-15, 10:58 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
led tail light install problem
Old 02-04-11, 08:43 AM
m0uz
m0uz's Avatar
Good evening,
Guys I'm new here.
And I have exactly the same problem and have absolutely no solution for it.
Can you PLEASE HELP me?
m0uz
Old 02-08-11, 12:53 PM
m0uz
m0uz's Avatar
Guys I really need your help!
As you've solved the problem with the taillights?
When I come to the installation of the rear lights as soon as I release the brakes several error messages on the display.
Need a solution for this problem?
Best regards m0uz
Old 02-08-11, 03:17 PM
pfdaxe
pfdaxe's Avatar
Best regards m0uz
'08 or newer? As stated...install a resistor on both taillights. Should eliminate codes.
Old 02-09-11, 12:22 PM
m0uz
m0uz's Avatar
'07 Lexus I have.
What kind of resistance I have to install the?
And between which of the veins? Between green and white or between green and black and between white and black?
Perhaps you have a picture like you did it?
But ever thank you for your reply.
best regards m0uz
Old 02-10-11, 11:19 PM
Hoovey689
Hoovey689's Avatar
redline201 told me that he used 25 watt 6.2 ohm resistors (I'm not sure how many on each side though), while tapping into the white and black wires. I'm going to go to RadioShack tomorrow and see if I can finally solve my problem
Old 02-11-11, 11:41 AM
m0uz
m0uz's Avatar
Thank you hoovey2411,
If you were with redline201 and you have solved your problem, you can still talk like redline201 attributed the problem solved?
THANK YOU
m0uz
Old 08-09-11, 10:10 PM
TrancEpimp
TrancEpimp's Avatar
eagle eyes on the left side and 07 oem connector on the right hand side.. the eagle eyes connecter is too small to fit..
person I bought it from said it was plug and play.. anyone else have pictures of your harness, or any other work-around. I don't want to split wires..
PS: I may just end up running ebay tails inner and oem outers..
Old 08-19-11, 07:38 PM
Hoovey689
Hoovey689's Avatar
So I tapped into the black and white wires and added a resistor to each as others have done. Installed them into the Eagle Eyes and the car is STILL throwing codes. I've about had it with these taillights and dunno what to do next. Any suggestions? I might have to scrap these and get some 2011 if I can't fix this..
Old 03-08-12, 09:56 PM
KL411
KL411's Avatar
Sorry, had to bring up an old thread. Has the code error been solved? I'm looking forward to the led tails shortly, but afraid of the codes it'll throw
Old 03-08-12, 11:01 PM
2genIS
2genIS's Avatar
i have the new version of LED tail light.. no error code.. they made a change in the plug so simply just plug n play...
Old 04-18-14, 10:06 PM
SuperiorSC
SuperiorSC's Avatar
bringing this back from the grave..............
I purchased the eagle LED taillights for my wifes ISX50, and I am having the same problem. my thoughts on the matter are "why not re-pin the connectors? remove the clips from the oem taillights and LED tails and swap them. My only problem is removing the oem clips. It seriously kicking my Xss. Any tips or suggestion? if I can get the oem clips of the new LED wires should plug right into it......right????????
Old 09-11-14, 07:30 AM
NikonGuy
NikonGuy's Avatar
I'm interested in these. Wondering if "new" ones on ebay have been revised so they don't throw out any more codes. I have a 2008 BTW
Silver'04
04-14-14 07:18 PM
robertrios
03-31-11 09:31 AM
garbage85
Lighting
12-23-08 11:25 PM
corkycal
03-24-05 08:06 PM
O. L. T.
Club Lexus Vendor Marketplace
43
05-04-04 10:26 AM
Quick Reply: led tail light install problem
