what are you guys using to lift your ride?
Old 10-12-10, 05:18 PM
nickhaaa
nickhaaa's Avatar
Default what are you guys using to lift your ride?
Long story short what are you guys using to lift the car so you can do the oil change?
So I recently bought a 2007 IS250 RWD 6MT. I like the car and have been enjoying it ever since September.
Now it is time for the oil change and I'm used to doing these myself. Doesn't seem that complicated. I bought a filter from the local Lexus dealership and got ready to do this.
When I went to lift my car I used the points behind the front tires that has the notches, where you would typically lift if changing a flat front tire. I used a Craftsman 4 ton low profile floor jack. I heard a loud pop and lowered it only to find that the metal underneath the car began tearing from the pressure. Not good. Pics attached.
Attached Thumbnails what are you guys using to lift your ride?-imag0167.jpg   what are you guys using to lift your ride?-imag0176.jpg
Old 10-12-10, 05:27 PM
vinconist
vinconist's Avatar
Use the jack that came with the car, and use jack stands to hold it up
Old 10-12-10, 07:33 PM
edgeucated
edgeucated's Avatar
i made the mistake of jacking it up by those jack points and one of the boxes inflated. Now i just jack it up by the frame. Its the two metal bars that run right behind those boxes you posted a picture of.
Old 10-12-10, 10:32 PM
Raralith
Raralith's Avatar
Originally Posted by LexusGuy35
Went to walmart and picked up an nice set of of plastic ramps for about $45
Pretty much this, Rhino Ramp's I think is what a friend uses. Purchased off of Amazon for a bit less too, no tax, fre shipping. Or you can do it the "ghetto" way and use your driveway to "ramp" the front right tire giving you enough room to slide under.
Old 10-12-10, 11:07 PM
mikemoto81
mikemoto81's Avatar
I bought Rhino ramps from Autozone......super easy for oil changes. Done in 20 min or less
Old 10-12-10, 11:17 PM
brociouz
brociouz's Avatar
For an oil change, +1 for Rhino Ramps.
Old 10-12-10, 11:23 PM
quang
quang's Avatar
get it done at local shop for less than $40 with synthetic blend, our car is too weak to be lifted
Old 10-13-10, 01:04 AM
sr20mofo
sr20mofo's Avatar
rhino ramps are coilover dumped friendly?
Old 10-13-10, 01:14 AM
PK_Celsior
PK_Celsior's Avatar
it might not be friendly depending on how low your car is!!! low profile jack with some block of wood ftw. the front pinch wells on the isx50 are very weak so you have to do it by the frame such as edgeucated explained. you can jack the rear pinch wells though with no flex. i have no clue why they made it like that but thats what it is.
Old 10-13-10, 02:22 AM
vinconist
vinconist's Avatar
nope, wont help either if you have a lip, had to sell my ramps
Old 10-13-10, 02:28 AM
masagsxr
masagsxr's Avatar
+1 on jacking it on the frame. I have a low profile jack that reaches almost half way through the other side of the car heheeheheee. I do however put the stands on those tho and try to lower it slowly.
Old 10-13-10, 12:34 PM
Jetfire
Royale with cheese
Jetfire's Avatar
http://www.mustangworld.com/ourpics/...amps/index.htm
Old 10-13-10, 02:16 PM
jpsilvia
jpsilvia's Avatar
The pinch welds are for stock jack only
the frame is not to be used for floor jack....it will dent in...it isnt designed for that type of load....a floor jack will cause a lot a pressure concentrated in a small area=dent in frame. frame rails should only be used for lift, (2post, in ground etc, where load is spread)
for a floor jack u need to use engine cross member for front and diff for rear.
Old 10-13-10, 02:34 PM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Lightbulb
It's in the Owners Manual people......
The OEM pantograph jack, is the only jack you should use on the this side rails..
Usually and only for emergency tire change situations
If your car is too low for a low profile jack, drive onto a strong piece of wood.
Regards,
Joe Z
Old 10-13-10, 02:41 PM
OPTiK
OPTiK's Avatar
Thanks for the post Joe! What about jack stands?
Quick Reply: what are you guys using to lift your ride?
