Common Problems with IS250
Old 03-07-12, 09:35 PM
  #31
scorpionge
scorpionge's Avatar
I just bought my 2008 last week and ALREADY got the noise on the center console dash speaker and my car has only 21k miles on it...
kinda pissed..
after working all day on it to get this now sucks =(
I found this pdf at least if its any help for someone
File Type: pdf
Old 03-09-12, 06:31 AM
  #32
scorpionge
scorpionge's Avatar
got it fixed under warranty, supposedly the middle portion of the speaker pops out whenever it get much juice.. so they just replaced it =)
Old 03-09-12, 10:55 AM
  #33
chikoo
chikoo's Avatar
1. Carbon buildup
2. Dash Rattle
3. Navigation Dead
4. Aux-in buzz
Old 03-09-12, 11:17 AM
  #34
cdubb883
cdubb883's Avatar
My navi is frozen, im repairing it today on my own...
Old 03-09-12, 01:11 PM
  #35
scorpionge
scorpionge's Avatar
apparently that aux is a problem on all models..
because my gf owns a 2012 and had to REPLACE THE AUX because it wasnt being recognized when the cable was plugged in
Old 12-12-13, 07:52 AM
  #36
AJBiel
AJBiel's Avatar
Default Popping in front of car
I bought a 2007 Lexus IS 250 AWD in July this year. When I make rather sharp turns (more often when turning left than right, and more often in reverse than in drive) I get a heaving and hard popping in the front of the car. It is progressively getting worse, and is particularly bad when the car isn't warmed up. The service tech at Lexus Spokane explained that there was probably nothing to be done with it. Everyone who knows cars and sits in my car explains that something is seriously wrong with my AWD. They compare it to an old truck that has been put into 4-wheel drive, and explain that "no lexus should ever do this."
Any ideas? Please help!
Thanks!
Old 12-12-13, 08:52 AM
  #37
Raybean
Raybean's Avatar
There is a fix for the aux buzz. Lexus added a in-line filter. part cost about $150 if your out of warranty. Why is your gf using the aux jack. Your model year should have the usb plug.
Old 12-12-13, 12:28 PM
  #38
Jamezy
Jamezy's Avatar
Thanks!
I get this in mine too (RWD), usually when pulling out of a parking spot or making a u turn. Basically any time the wheel is turned all the way, thought it was my axles going but they looked fine when I inspected them.
Old 01-13-16, 04:11 PM
  #39
Mandie
Mandie's Avatar
I'm new to this forum and I desperately need help! My vehicle is an 07' Lexus IS250. I've never had any problems with it until now. Every time I press the brake to start the car, the button does not turn green. If I keep pressing the brake, it gets suctioned to the floor. Before I would just lock the car and leave it alone for a moment and when I would come back, the car would start fine. Well, the brake has not reset itself and its been about a week now. No problems with the battery or any of the fuses. Oh and my brake lights don't work either. I'm thinking that ties in. Advice is greatly appreciated!!! Thank you
Old 01-13-16, 09:15 PM
  #40
nikogio38
nikogio38's Avatar
No power...
Old 01-14-16, 12:27 PM
  #41
Gville350
Gville350's Avatar
So were you able to get the car running or not? If not, since you have no brake lights, does the dome light even work...meaning, a dead battery?
The brake pedal will normally get very stiff after a few presses with the car remaining off. When turned on, a vacuum source is introduced to the master brake cylinder releasing most of that pressure making the brake pedal feel normal.
Old 01-15-16, 12:31 PM
  #42
KIS350
KIS350's Avatar
Could be wiring to the brake switch? As niether the ignition or brake lights are getting the signal that the brake pedal is being utilized? Good place to start maybe...
Also if your break pedal goes to the floor and gets stuck there before the car starts I would even look at your brake pedal linkages. Perhaps something has come loose rendering the switch inoperable...
kjacks1792
Suspension and Brakes
08-21-11 06:44 PM
Brian231
02-15-08 07:06 AM
isam250
06-05-07 07:54 PM
isam250
04-20-07 02:53 PM
viettho
17
04-04-07 07:16 PM
Quick Reply: Common Problems with IS250
