Parking brakes don't hold
I have only 5600 miles on my 07 IS350. The parking brakes doesn't hold the car on a hill. I have to use the transmission (P) to hold the car. Anyone here with the same issue?
Does anyone know if it can be adjusted without removing the rotor and caliper? I have an old fashion drum brakes, spoon. Wonder if it will work.
Liquid Bra Champion
I have only 5600 miles on my 07 IS350. The parking breaks doesn't hold the car on a hill. I have to use the transmission (P) to hold the car. Anyone here with the same issue?
Does anyone know if it can be adjusted without removing the rotor and caliber? I have an old fashion drum breaks, spoon. Wonder if it will work.
hahaha... sorry. I need to proof read in the future. Thanks!
I like to put the car into neutral then press the foot parking brake and wait till the car settle on the brakes prior to putting the transmission into (P) park. This method allow the brakes to hold the car not transmission.
Ever noticed when you just put it into (P) park and then the parking brakes, when you release the (P) it make a clunk sound? This is due to the transmission holding the car.
yea rear brakes have very small adjustment they have really small shoes inside the rear rotors but there should be a rubber plug look for the star wheel and adjust it
It is best to engage the parking brake on a hill first and then place the AT in P in order to reduce wear on the tranny. Over time, using the tranny alone to hold the car will cause premature wear. Also, if you never engage the parking brake, it will lock up and the springs will cease (over time). Typically, in the position to not lock the rear wheel.
What about releasing the parking brake? Is it best to release the parking brake first before putting it into drive, or is best to put it in drive mode then release the parking brake?
Yes,
I always park on an incline with AWD so all 4 axles are locked in park. The parking brake could be a little stronger IMO. Their should be an adjusting hole on the hub of the rotor. If not, just pop off the whole rotor (caliper as well) and adjust with the whole drum assembly exposed. It is very easy to do. Sometimes, you will have to give the hub a couple of hits with a hammer (being careful not to ding up rotor surface) in order to break through the potential corrosion.
No need to put it in neutral. Here's my method:
Hold footbrake, with other foot engage parking brake, then put car into P, then release footbrake. When leaving, hold footbrake, release parking brake with other foot, then put car into gear. It's become second nature for me.
EXACTLY how I have always done it! Second nature to me too, I think I have always done it like this with previous cars.
Tech Info Resource
Yes,
