Awkward noise coming from engine
I read a thread about a clank noise that some people heard when they started their 2IS. That isnt the problem with my car. It sounds like a loud ticking sound. I first thought it might be the fuel injectors and when i took it to lexus, they said the same thing. Couple of my friends noticed the same sound and said that there was something wrong for sure. I took off my intake to make sure that that wasnt the noise and sure enough, it wasnt. My next guess is that it might be the rocker arms...Does anyone else have the same problem?? Is this normal?
I once had this noise (if i can still recall it to be the same noise) but felt it was dur to the thin oil i had used (0-30w). Switch back to 10-30w and it seems to be better...
This noise?
https://www.clublexus.com/forums/sho...d.php?t=309197
If so, its not normal..and there is a TSB on it
This noise?
I dont know if this is the right way to compare it, but my car almost sounds like a diesel car running
^^^I have the ticking noise as well...it sounds like a diesel
i only hear it when im going through a drive thru...due to the noise bouncing off the walls of the building...as soon as i get the vehicle away from the building the ticking goes away
If ya have the ticking noise, I think the 06-07 IS250/IS350 have the fuel system recall.. I work at Lexus dealership and Ive seen few 06-07 IS on the jack lift.. GO there and ask the service department about the FUEL system and I believe your car have warranty...
skydash
05-16-17 09:06 PM
