Aftermarket AMP and SUB install
Old 11-08-07, 11:15 PM
chat0882
chat0882's Avatar
Default Aftermarket AMP and SUB install
I've been around the boards over and over searching and couldn't find answers I was looking for... What exactly will I need besides Amp, Sub, amp kit to hook up 2 12" subs and an amp to the stock system? I'm trying to do some homework before I go out and get things ripped apart and installed. I need to know they know what they're doing by asking yall here first. Thanks for your help
Old 11-09-07, 12:12 AM
Zanorath
Zanorath's Avatar
That's mostly all you'll need, a few wires, they'll need to tap into the wiring from your rear door speakers unless you have an aftermarket head unit. I recommend a capacitor, but its definitely not required.
Old 11-09-07, 06:10 AM
chat0882
chat0882's Avatar
So as far as my Hz range, I did read one post when dude tapped into some wires somewhere and his range was only filtered range the stock sub could handle 50-80hz I believe. What's the way around that?
Old 11-09-07, 06:47 AM
tt061880
tt061880's Avatar
you didn't search hard enough my friend. I did a write up on this a while back, it will answer most of your question and has a low cost solution to get great sound from the stock system.
https://www.clublexus.com/forums/sho...light=TT061880
Old 11-09-07, 08:06 AM
chat0882
chat0882's Avatar
So that I understand, instead of just tapping into the sub wires with minimal freq, you used the sub woofer AND the front 2 woofers wires hooked up to the LOC for full freq and then hooked up all that to the amp and good to go right?
Old 11-09-07, 11:51 AM
tt061880
tt061880's Avatar
yes...........
Old 11-12-07, 07:35 AM
chat0882
chat0882's Avatar
I couldn't quite see, but did you tap into the wires while they're still connected to the harness or did you just clip them from the harness and connect?
Old 11-12-07, 07:53 AM
gsrthomas
gsrthomas's Avatar
Will the Scosche LOC work on non ML setup the same way for ML guys??
Will I need a 4 or 2 channel?
Old 11-14-07, 12:08 PM
chat0882
chat0882's Avatar
Got everything installed, the subwoofer was the only thing tapped into with the LOC, i'm about to adjust the crossover on my amp today. It sounds GOOD!! 2 12" in a sealed box... It's not too much at all nothing is rattling, and I mean NOTHING. It sounds so crisp and clean!!!
claytons91
SC- 1st Gen (1992-2000)
04-18-14 07:15 PM
Toxicxk23
08-12-12 05:09 PM
aznpapaya
06-28-11 12:37 PM
tubsytmac
09-04-09 03:29 AM
Daynja
06-08-07 12:37 PM
Quick Reply: Aftermarket AMP and SUB install
