IS350 Paddle Shifting Quirk
If I set the trans to operate in S Mode and I give the throttle 100% and attempt to short shift at say 6,000RPM, the transmission fails to upshift until the engine gets to redline.
However, if I do the same test but I keep the throttle at say 50%, it upshifts exactly when I request it with the paddle shifter.
Is this normal? Is there a way to disable this function?
I want the trans to upshift as per my request only, like an Audi Tiptronic or BMW SMG.
Thanks!
JP
Thanks!
JP
Thanks!
JP
Thanks!
JP
Now i hit the paddle around 5000 so it shifts just before the red line or usually right on it. Only short shift it if going from first to second for obvious reasons.
2IS OG
That's because your paddle shifter are not true paddle shifters. They are "top range gear selectors." The only control you have over the transmission is the maximum gear the car is allowed to shift into. In other words, if you paddle up to 4th, then you are in essence giving the automatic transmission permission to select any gear up to 4th. The Tiptronic or DSG functionality you guys are looking for is simply not possible in this car.
Javier
Javier
Welcome to the worst thing about the IS: those idiotically useless paddle shifters.
The best way to deal with it is just to click down into 1st gear whenever you shift into S (hopefully at low speeds ) and just flick up as you near the redline. That gives you pretty much the most amount of control over the gear changes in the IS.
I didn't think I'd ever find use for the paddles until I drove this weekend up the mountain to Ridge Vineyards in Cupertino. Anybody who's ever done that drive can attest it is one really scary drive, with really narrow roads for 2 way traffic, and minimal mirrors to see oncoming cars.
The paddle shifters worked well to keep the car in a lower gear, though that run killed my gas mileage. On flat grounds, the shifters are pointless.
TopGearLA
02-20-12 04:07 PM
