Mirror Coverage for clear bra
Old 04-20-06, 09:51 AM
AndyL
AndyL's Avatar
Default Mirror Coverage for clear bra
For those who has clear bra installed,
I have the VentureShield film installed and notice that the side mirror is only covered up to half way of the mirror, literally leaving a seam in the middle of the mirror if you look side-way.
The shape of the mirror looks like an undersized version of the mirror concour. And the seam doesn't coincide with the existing design groove, makig it a pretty ood look.
I pretty much believe it is an Invisible Pattern pre-cut design.
How does your mirror film look like?
Old 04-20-06, 09:52 AM
AndyL
AndyL's Avatar
Typo. I meant to say "the shape of the mirror film looks like an undersized version of the mirror contour."
Old 04-20-06, 10:23 AM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
Mine isn't covered completely as well. A 3M kit was used for my car. I don't think it's much of a bother anyways; I'm more concerned about the body of the side mirrors, rather than its edges as they are less likely to have deep chips/scratches.
Old 04-20-06, 10:31 AM
IS350_F1
IS350_F1's Avatar
Mine start on the flat part of the inside next to the car following the edge, then pulled across the fwd facing (rear section of the contour) its split in the middle to straddle the seam and maximize coverage arount the outside corners and not quite to the top seam ridge. Very nicely done. I got the same venture film on mine... infact I met the regional dealer/installer for the company and he was like.. damn.. thats good work on the mirrors.
Old 04-20-06, 05:22 PM
AndyL
AndyL's Avatar
IS350_F1 and those who have clear bra installed,
Does your mirror film look like this?
Old 04-20-06, 05:38 PM
linh811
linh811's Avatar
It's not too clear on your pics, but it looks like it has MORE coverage than my 3M film.
Old 04-20-06, 07:50 PM
IS350_PHIL
IS350_PHIL's Avatar
AndyL - Can you wax over the top of the clear bra or do you have to wax around it?
Old 04-20-06, 08:01 PM
JamRWS6
JamRWS6's Avatar
You can wax over the film but you have to be careful around the edge so wax does not build up.
Old 04-20-06, 08:08 PM
AndyL
AndyL's Avatar
Yes, it can be waxed over. Just be careful not to wax across the seam or you will have the wax buildup and you need the time to clean it up.
In fact, on the VentureShield warrranty card, a line says "Apply a good grade of automotive wax to your VentureShield film precisely as you would to the underlying paint finish"
linh811,
you should see that there is a seam which is not in line with the edge of the mirror..
AndyL
AndyL's Avatar
So that's the best coverage for the mirrors for those who got the bra installed?
Old 04-21-06, 07:22 AM
AndyL
AndyL's Avatar
May I ask if there is anyone who would like to post a pic of their mirror with the clear bra?
Thanks.
Old 04-21-06, 07:31 AM
Tony1
Tony1's Avatar
I have venture as well, and mine is doen EXACTLY like that...
Drummond
02-02-18 06:46 AM
Lextranny
09-24-13 12:50 AM
thall
01-17-12 04:13 PM
mattssi
10-02-06 08:49 PM
Quick Reply: Mirror Coverage for clear bra
