IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Power loss, but no cel
Old 11-30-13, 11:37 PM
GS FONZy
GS FONZy's Avatar
Default Power loss, but no cel
My girl's IS has a lack of power up in the higher rpm range.. After 4k I feel the car starting to struggle. I've done a tune up and it helped, but it doesn't feel like an IS should. Car runs ok in the lower rpm range but I can tell it's not like it use to be. The car idles fine too, so I'm wondering if anyone has had this issue? Any ideas are welcomed since with no cel it's anyone's guess at this point.
Old 12-02-13, 12:05 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Are you sure there is no check engine light - make sure it turns on when you turn the key on but the engine isn't running...
Aside from that, your issue will definitely be hard to diagnose... When is the last time the plugs were changed? How many miles are on the car?
Old 12-02-13, 03:17 PM
MURPHY660
MURPHY660's Avatar
Check plugs for wear, also go ahead and clean the MAF and TB with correct cleaner
Old 12-03-13, 06:40 AM
is3wagon
is3wagon's Avatar
What parts did you replace with your "tune up"?
Old 12-25-13, 07:56 PM
GS FONZy
GS FONZy's Avatar
Found the issue, it was the third cat. Thanks for your replies.
masitaly17
05-29-18 05:53 PM
Jimynutz
10-24-16 01:06 PM
davids75
Performance & Maintenance
01-06-13 08:16 PM
tlex400
12-27-05 09:02 AM
Quick Reply: Power loss, but no cel
