IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Dashboard lights came on during sleet!!
Old 12-24-12, 01:32 PM
01BabyLexy
01BabyLexy's Avatar
Default Dashboard lights came on during sleet!!
Hello all,
I was driving home from work today and the weather was sleeting. Not real bad. I was on the highway and at one point felt that my front tires lost traction or control. It was for a few seconds, but I remembered seeing the brake light and a few instrument lights came on. After those few seconds, the car regain control and the lights went away. Is this normal?
Old 12-25-12, 07:17 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Sounds normal... not sure about the brake light, the one light you should see is the VSC / Traction light flash while in low traction situations...
Be safe though, slow it down, get better tires, both, it can't always save you!
Old 12-25-12, 08:37 PM
2broke2mod
2broke2mod's Avatar
this. your VSC light will automatically kick on when the car senses a loss of traction. Did it shut your motor down also to regain control? Are you sure is was the brake light? I don't believe these lights are suppose to come on during this situation
Old 01-01-13, 01:55 PM
01BabyLexy
01BabyLexy's Avatar
UPDATE!
It wasn't the lost traction that caused this problem! I was on the highway doing about 75mph and all of a sudden, my car would lose all electrical power for 2 seconds and then it would come back again. This problem kept happening every 1 hour or so. I found out that my negative battery connector was corroded and after a little baking soda and cleaning, the problem went away. **crosses fingers**. Thanks all for your help.
Gtzfabb
04-25-16 11:52 AM
bofronado2
04-16-14 01:58 PM
repetedb
SC- 1st Gen (1992-2000)
06-07-10 09:28 PM
archangels
RX - 1st Gen (1999-2003)
24
05-27-08 02:50 PM
ES3302005
03-16-08 05:43 PM
Quick Reply: Dashboard lights came on during sleet!!
