HELP!!! brake light,abs,and trac lights are on
A few weeks ago i was driving and my abs light, traction light and brake light all came on. I took it to lexus and they told me it was my battery.They gave me a new battery and a week later the lights come on again. So my car is at lexus now and they called and said they dont know whats wrong and that they wanted to drive 50+ miles to see if the lights come back on.
Has anyone had this problem..HELP PLEASE.
My Analysis
The IS300 is using speed sensors in the wheel hubs. These sensors are connected to wires that are having connectors. I am having the same issue for a month now. I didn't take it to the dealer because I am not sure how much they will charge to diagnose but I am planning to remove and check the sensors and inspect the wiring and connectors for any rust, corrosion etc. If you find anything, kindly share it.
Apart from that I read in few forums and some say that you also should check your transmission fluid level which may be the cause. I also read that some check lights also come ON when you refuel the car without turning it off.
I hope you resolve the problem easily. Do share the results in detail
