Anyone have Sikky and ISS QES? Or can explain how the Sikky 02 sim works?
I can't believe I am still doing this. I am running sikky and ISS QES, and I cannot pass inspection due to no heater sensor and no 02 IM monitors on the scanner. I have swapped two sets of upstream 02's and 2 sikky 02 sims, still no luck.
Can anyone explain if the sikky 02 sims account for upstream and downstream02's? Just want to know how they work. I am assuming my downstreams do not read at all from the ecu due to the 02 sim, and the upstreams then should just read as normal and would therefore be the reason the IM monitors are not turning on. Any advice is greatly appreciated. I am tearing my hair out trying to figure this problem out.
I read they simulate the downstream to the ecu, the ppe conditioners *will* get you to pass with flying carpets due to the fact the emissions reader will test and it *will* get correct response/readings. Wanna sell me a sikky sim? I'm after one since I don't have emissions testing and it seems less hassle to not jack up the car
