apexi smart accel question...
Old 12-10-14, 10:01 AM
Ltaboso
Ltaboso's Avatar
Default apexi smart accel question...
I read on the manual it says while on boost mode or hi-throttle mode...it will go back to "normal" mode once the accelerator is fully open.
Does this mean if i was using the "boost" mode (red) on the track,after flooring the pedal,it will return to normal,then i have to select "boost" mode again?
Or it stays on "boost" mode all the time unless you turn the unit off?
Old 12-10-14, 10:44 AM
PDP180180
PDP180180's Avatar
You will not lose red mode unless you manually change the setting (push the button up or down), hold the button down (turns the controller off), or switch off the engine.
It will stay in red mode otherwise.
It will also remember the last mode you used when you turn it back on.
Hope this helps.
Old 12-10-14, 10:48 AM
Stuno1
Stuno1's Avatar
I understand the controller only enhances initial response. Once the Pedal is fully depressed it is normal for sport/normal/snow
Old 12-10-14, 10:55 AM
Ltaboso
Ltaboso's Avatar
Hope this helps.
Thanks for the reply...looks like i will be buying this for xmas =)
Old 12-10-14, 01:32 PM
PDP180180
PDP180180's Avatar
Glad to help.
As Stu mentioned, the controller only affects pedal response.
Red mode basically cuts the amount of force/pedal travel down by around half.
You will get faster response, with less effort.
I'm enjoying it as a middle ground between normal and sport mode.
The button is also a lot easier to reach than the sport mode button on my 2008 model.
It's certainly a nice mod for minimal outlay.
Just make sure you buy the ISF specific harness to go with the throttle controller.
Old 12-15-14, 07:39 AM
Ltaboso
Ltaboso's Avatar
Hey guys, i just got my apexi throttle controller today and will install it soon, this thing has so many modes, which mode is the 1:1 feel? For me the 1:1 is the cable type accelerator
Thanks
Old 12-15-14, 08:35 AM
PDP180180
PDP180180's Avatar
Thanks
Hey,
Glad to hear you got your controller.
Not quite sure what you mean by 1:1 mode?
The OEM setting would be achieved by having the unit switched off completely (hold down the bottom button till the lit Apexi logo goes off).
The other modes/colours are as follows:
Eco mode 1 - white
Eco mode 2 - light blue
Eco mode 3 - dark blue
Low throttle - green
Boost 1 - yellow
Boost 2 - purple
High throttle - red
I only really use the boost and high throttle modes.
For normal driving, I have the unit switched off (this will happen automatically when you start the car for the first time. The unit will only operate if you switch it on).
Think of it like you do the sports mode (off until you want to use it).
Hope this helps.
Cheers.
Peter
Old 12-16-14, 05:45 AM
Ltaboso
Ltaboso's Avatar
Got it installed today and calibrated it, seemed like i calibrated it correctly because the unit stopped blinking white...then all the colors seems like they're functioning....but does the throttle controller LED (on the mode you are using) really blink everytime you will step on the accelerator?
Old 12-16-14, 07:06 AM
PDP180180
PDP180180's Avatar
Not that I noticed??
It just stays the colour of the mode I am in from memory.
Old 12-16-14, 06:17 PM
Ltaboso
Ltaboso's Avatar
That's weird....can you check if it blinks as you step on the accelerator next time you drive your F...
Thanks
Old 12-16-14, 06:55 PM
yjk1975
yjk1975's Avatar
I am on yellow all the time. Yes it blinks.
Old 12-16-14, 08:11 PM
Ltaboso
Ltaboso's Avatar
Ok thanks alot, now i have a piece of mind its normal =)
clammbo
11-07-21 04:46 AM
handzilla
11-24-15 11:19 AM
yardie876
02-07-13 01:29 PM
E12ic46
Hybrid Technology
08-06-10 06:19 AM
G35TOIS350
07-28-06 08:43 PM
Quick Reply: apexi smart accel question...
