Jack question
07-26-14, 08:52 AM
Jack question
Is it safe for the isf to get jacked up like this?
07-26-14, 09:48 AM
i woudlnt' be climbin under there, ha
07-26-14, 10:13 AM
what part of the car is the jack being applied at?
07-26-14, 10:16 AM
Not sure. It's not on the pinch welds though
07-26-14, 01:32 PM
Tech Info Resource
Safe for the car or safe to work on?
07-26-14, 05:25 PM
Quote:
Originally Posted by
lobuxracer
safe for the car and safe to work on.
07-27-14, 08:34 AM
BlackISFtx
my money is on yes, no. hmmm, but then why do it in the first place.
07-27-14, 03:41 PM
07-27-14, 05:49 PM
Tech Info Resource
I've lifted the car like that with a floor jack on the body seam at the jack point without issue, but I would never get under a car without putting it on a jack stand first. It is very convenient to lift the car this way to change brake pads at the track.
07-27-14, 09:25 PM
It's safe for the car. As others have mentioned if you plan to go underneath use jack stands.
BTW that's a lot of Z's in one shop hah.
07-29-14, 05:07 PM
what about using these areas to lift the isf?
07-29-14, 10:06 PM
07-29-14, 11:20 PM
Tech Info Resource
BlackISFtx
Not recommended. Only the body floor pan seam is expected to support the car, not the frame rails. They will dent. AMHIK.
07-30-14, 01:39 PM
Thanks lobuxracer! what if they get dented?
07-30-14, 06:22 PM
Tech Info Resource
Hopefully nothing serious. There's not a lot you can do to fix them without welding on some small nuts and slide hammering them out. Worst case (very, very unlikely) you can bend the chassis. You'd have to drop it pretty hard on the stands to do that though.
AZN Lex
SC- 1st Gen (1992-2000)
11-01-15 08:43 AM
leisinjp
IS F (2008-2014)
26
09-18-15 01:54 PM
LINDSDST
Automotive Care & Detailing
57
12-24-13 08:16 AM
SVT2888
12-02-10 09:13 PM
ULTiMaX99
08-14-06 09:09 AM
