19K, time for some tires
Hey all,
I am in for my 20K service and the dealership is advising that I need new tires. They want nearly 1.8K for tires and an alignment.
1. Should I just get the OEM tires from an alternative vendor?
2. If not, is there a better (read: less expensive) alternative to the OEM tires that I should look into without sacrificing on performance ?
Best,
Eric
Best,
Eric
you shouldnt have to get an alignment after getting new tires unless your tires were wearing unevenly. People here seem to go with 20mm wider tires all around on stock wheels (245 front /275 rear). PSS is the best street tire you can get. Has anyone tried Conti DW? OEM tires are usually trash anyways. You can always find tires that are less expensive and better performing.
Many Many threads concerning tires for the ISF. May I suggest:
https://www.clublexus.com/forums/is-...or-my-isf.html
https://www.clublexus.com/forums/is-...se-a-tire.html
And My Favorite:
https://www.clublexus.com/forums/is-...-position.html
Lou
And My Favorite:
Lou
