Aftermarket Lug Nut.
That really depends on your lugs. Without any key you'd most likely need to smash socket over the lock nuts with a hammer and then hope it is tight enough you can loosen them.
The best thing to do would be to look into finding replacement adapter keys. It should be inexpensive and not much trouble if you know what brand the lug nuts are.
That really depends on your lugs. Without any key you'd most likely need to smash socket over the lock nuts with a hammer and then hope it is tight enough you can loosen them. The best thing to do would be to look into finding replacement adapter keys. It should be inexpensive and not much trouble if you know what brand the lug nuts are.
^ Wait are those ok to use on OEM wheels? I.e. are they safe?
if yes, then these are the same correct --> http://www.ebay.com/itm/Neon-Chrome-20-pcs-1-Key-12x1-5-MAG-Stock-Factory-OEM-Wheel-Lug-Nuts-A107-A01-/171348414144?pt=Motors_Car_Truck_Parts_Accessories&hash=item27e5294ec0&vxp=mtr
Tech Info Resource
https://www.amazon.com/Gorilla-Autom...dp/B00G92F9E0/
I don't run them though but Belak is known with the quad digit racecars
Check RealStreetPerformance out
https://www.realstreetperformance.co...ead_size=55634
Rossi (02-25-23)
Sorry for bringing back an old(er) thread. I have extended studs - and want to run my OEM's when I'm off the track. Was anyone able to find open ended mag-style lug nuts with washers?
ScBouncE
SC- 1st Gen (1992-2000)
01-27-14 06:58 AM
leosls400
02-04-05 01:12 PM
