ISF Oil Change
Old 05-16-14, 02:13 PM
RCB
RCB's Avatar
Originally Posted by nzk
Lift is relatively cheap, $1999 shipped from Costco. Has paid for itself in 6 months with all the work I have done on it.
The lift nzk has is ideal for homeowners. It can be moved out of the way when not in use and the biggest plus is that the posts are not to high for ceiling under 12'.
It really does pay for it's self if you do a lot on your cars or friends cars. Plus it saves your body from a ton of abuse.
Old 05-16-14, 03:12 PM
flowrider
flowrider's Avatar
Received 1,831 Likes on 1,293 Posts
One of my dreams, has always to have my own pit. I've always had my houses built, but I have never really explored getting a pit. One of my regrets.
Lou
Old 05-16-14, 07:25 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Originally Posted by RCB
The lift nzk has is ideal for homeowners. It can be moved out of the way when not in use and the biggest plus is that the posts are not to high for ceiling under 12'. It really does pay for it's self if you do a lot on your cars or friends cars. Plus it saves your body from a ton of abuse.
it looks bolts to the floor?
Old 05-17-14, 08:45 AM
iH8RICERZ
iH8RICERZ's Avatar
that is one spotless 3 car garage!! And yes, I'm also jealous of the lift... if I still wrenched on the cars every week, I'd invest in one, but all I do now is oil and brake changes.
Old 05-17-14, 11:55 AM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Awesome...
Home Lift is my next mod..
Small tip with the foil.. Use it in the trans cover, as that is where most of the mess occurs.
(drain plug)
~ Joe Z
Old 05-17-14, 12:44 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
I bought this house because it has a 12' ceiling in the three car garage. That lift is designed for 4" concrete (standard home pour), not 6" like the rest of them, and as was said, it can easily be unbolted from the floor and moved out of the way.
The wife hates me working on cars on jack stands, so she's 100% behind the purchase. Definitely on the home improvement list!
Old 05-17-14, 01:39 PM
dannyk8232
dannyk8232's Avatar
^^^^^^ Well in the name of safety, I believe you should git 'er done asap!
Old 05-17-14, 06:36 PM
nzk
nzk's Avatar
Originally Posted by Joe Z
Awesome...
(drain plug)
~ Joe Z
Yea realized that too late! Foil will be in the correct spot next time. Thanks for the compliments, I have been working on cars on my back for many years (trans pulls, susp work, exhaust etc) finally had the room to get one, highly recommended.
Old 11-04-15, 05:32 PM
nzk
nzk's Avatar
wanted to add procedure for oil light reset:
1. Start the car and set the odometer to the total vehicle miles setting 2. Turn off the car 3. Hold in the odometer button 4. Turn the car on by pressing 'start' twice but DO NOT start the car (don't press the brake pedal) 5. Continue to hold the odometer button in until it resets to all zeros 6. Let it go
Old 11-04-15, 05:55 PM
Joe Z
Joe Z's Avatar
Lightbulb
1. Start the car and set the odometer to the total vehicle miles setting 2. Turn off the car 3. Hold in the odometer button 4. Turn the car on by pressing 'start' twice but DO NOT start the car (don't press the break peddle) 5. Continue to hold the odometer button in until it resets to all zeros 6. Let it go
Or just watch this Video....
azncapcom
06-15-20 06:51 AM
Joker4096
IS F (2008-2014)
02-28-16 05:40 PM
chrisfan
IS F (2008-2014)
18
12-07-13 01:23 PM
LEXUSF
IS F (2008-2014)
31
05-18-13 08:54 PM
wakaru8
12-23-09 08:07 AM
Quick Reply: ISF Oil Change
