Oil change without a filter
Old 01-11-13, 02:59 PM
digger08
digger08's Avatar
Originally Posted by Jowett
Toyota put a tech tip out to dealers in Canada concerning the use of a proper SSTool so as not to strip the housings. The stamped steel units are the worst... but there are a couple of wrenches that work better than the rest... this one won't get stuck or strip. I suspect it will take stripped housings off even.
http://www.ebay.com/itm/Toyota-Lexus...item337f193899
Thanks Jowett, I'm actually in the oil change business for over 22 years,.......and live in Canada....and I've never seen this tool before!
I learned something new this week.
Digger08
Old 01-11-13, 03:12 PM
TTechLexus
TTechLexus's Avatar
I broke 4 filter removal wrenches the first time I tried to change the oil
Whoever put it on before must have been related to the hulk
Eventually the 5th time was a charm, 2 days later, and a sore hand
Old 01-11-13, 03:56 PM
digger08
digger08's Avatar
Even applying the correct torque setting when reinstalling this cap...its inherent that the next removal can be difficult, with heat, plastic, "O" ring etc......not necessarily the last guy that touched it.
It helps to use some torque on the cup wrench by using a longer extension when removing the end cap sometimes.
Digger08
Old 01-12-13, 05:24 AM
Jowett
Jowett's Avatar
The tool is new, a member on the Tundra Forums came up with it.
Old 01-12-13, 11:45 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
That's a kickazz tool! It beats the snot out of the fluted cup, and it's dead simple. The only thing I don't like about it is the 3/8" drive. If it were 1/2" drive it would be in my toolbox...
I always use 1/2" drive tools on the filter housing. It needs a lot of torque to break the seal, and an 18" breaker bar is easy to tension and tap to get the filter housing moving.
Old 01-27-13, 11:12 PM
allst4risf
allst4risf's Avatar
how much oil do we put in the f? 8.7 or 9.8?
Old 01-27-13, 11:41 PM
Just F Me
Just F Me's Avatar
9.8...that's what the manual says. fill it up...check your dipstick...start the car....let it run for a bit...check the dip stick again just to make sure.
azncapcom
06-15-20 06:51 AM
USCRugby
04-21-13 10:52 AM
sallydrive
10-06-12 06:02 PM
lilbluu
06-01-10 03:44 AM
wakaru8
12-23-09 08:07 AM
Quick Reply: Oil change without a filter
