ISF Steering feel
#31
Has anyone upgraded the ECU on isf?
I found the part on the Sewell site....$443.81
http://is.sewellparts.com/accessorie...2011/5645.html
This should be plug and play affair.
Thee bolts and connect the wires.
#32
Tech Info Resource
There's a "yes, but" that goes along with this. You'll need to have someone with a Techstream subscription calibrate the new ECU to your rack. So, either a Lexus dealer or a good Lexus independent will be needed to get it working correctly. You can drive the car without the calibration, but I wouldn't drive any farther than the nearest place you can get this done.
#36
I'm almost certain that a weight in the center of the wheel isn't increasing the resistance of turning the steering wheel. The weight of the steering wheel doesn't bother me, I just wanted input from other ISF drivers to confirm that my power steering is or is not operating properly.
Hope this help.
#38
Mr2KiEu
03-14-21 12:23 AM
CAN-Toronto 2014 Lexus ISF steering computer
Compthis
14
04-06-16 11:34 AM
aloha08isf
IS F (2008-2014)
05-16-10 01:41 AM
