IJDMTOY DRL LED's w/ new slim decoder - installed
Old 09-11-12, 11:25 PM
rc2o6
rc2o6's Avatar
Default IJDMTOY DRL LED's w/ new slim decoder - installed
Hey guys,
I purchased ijdmtoy's DRL LED's with their new redesigned slim decoder. I got them from the vendor classifieds and sent PM's back and forth. Perfect fitment inside the dust cap, no drilling or modification needed. Check out the pictures.
However, installation was definitely a PITA on the passenger's side as I didn't remove the intake box but still a super simple install.
Vendors Classified thread:
https://www.clublexus.com/forums/clu...-and-hids.html
Bulbs from their website:
http://store.ijdmtoy.com/9005-LED-Da...d_sku45_r4.htm
Use this thread for installation reference: https://www.clublexus.com/forums/is-...ts-w-pics.html
Pictures:
Also installed mirror puddle lamps too
I love the new look of the drl's, so much better than the oem bulbs
Old 09-11-12, 11:52 PM
JDMV8
JDMV8's Avatar
good look.
I'll probably be ordering 2 slim decoders for mine, did not know that it would fit in without modifying the moisture guards!
Old 09-12-12, 12:21 AM
aWorkOfArt
aWorkOfArt's Avatar
Looks good bro! Bright as f***!
Old 09-12-12, 01:13 AM
ShadowISF
ShadowISF's Avatar
They are bright but I like them a lot!
Old 09-12-12, 03:47 AM
Boma
Boma's Avatar
I have the same modification except I used the kit from V-LEDs. It's a way improved look over OEM yellow! You're right about the installation, a PITA unless you have tiny, flexible hands! I managed to squeeze the entire module inside the moisture guards.
How is your hi-beam capability though?
Old 09-12-12, 07:42 AM
DonTN
DonTN's Avatar
I have the bulbs in, just haven't gotten around to installing them. Mine didn't come with the decoders. What do the decoders do and are they necessary?
Old 09-12-12, 08:01 AM
vuhnilla
vuhnilla's Avatar
They look awesome!!!
Old 09-12-12, 09:54 AM
iH8RICERZ
iH8RICERZ's Avatar
Have any pics of the headlights when they're not on? I want to see if the LED bulb is visible when the lights aren't on.
Old 09-12-12, 10:15 AM
Got F?
Registered User
Got F?'s Avatar
About a year ago I took my 2008 ISF to Jotech Motorsports in Garland, TX to have my DRL bulbs switched to LEDs. After about 45 minutes they came back and said they couldn't do it because the LEDs kept flickering. Has anyone else experienced this problem or know why it was happening? Thanks!
Old 09-12-12, 10:26 AM
bnizzle87
bnizzle87's Avatar
Much brighter than the OEM, which I like. I also like that there was no modification to the dust cap. Great work!
Old 09-12-12, 10:27 AM
rc2o6
rc2o6's Avatar
I'll go take some photos later today and post them up. The high beams are still functional although not as bright as before, I still get that extra brightness and low beam transitions itself higher so it still works.
Yes, the decoder is necessary. From ijdmtoy's website "the special daytime running light (DRL) decoders will ensure the LED bulbs light up without malfunction issue nor flickering issue."
I'll take pictures later today and post them up.
You'll need the decoders... from their website "the special daytime running light (DRL) decoders will ensure the LED bulbs light up without malfunction issue nor flickering issue."
Old 09-12-12, 11:06 AM
SeanGTS
SeanGTS's Avatar
Can someone explain why this changes the high beam function?
Old 09-12-12, 11:25 AM
CCColtsicehockey
CCColtsicehockey's Avatar
I assume these are useless as high beams though?
Old 09-12-12, 07:53 PM
Boma
Boma's Avatar
^^ the high beams act as the daytime running lights at low power (on '08 to '10 models I believe).. LEDs are dim in comparison to stock halogen lights.
^ the high beam functionality is compromised, but it is not lost completely. The low beam projector actually has a "flap" that opens and closes when you toggle the high beam. So you will still have the high beam and it will be noticeable to other drivers, it just won't be as bright.
In my experience, I use the old module/decoder and the fuse for the high beam blows out if I use the high beam for too long, killing the DRL functionality. I keep a pack of low-profile 15amp fuses handy just in case.
Old 09-12-12, 09:21 PM
rc2o6
rc2o6's Avatar
Bulb without the car on:
Another shot of the drl led's:
So far so good. It was a simple plug and play setup, very straight forward.
Quick Reply: IJDMTOY DRL LED's w/ new slim decoder - installed
