Manual Mode
Old 03-03-12, 08:11 AM
xjason
xjason's Avatar
Default Manual Mode
When driving in manual mode, is it possible to go past redline or does the transmission shift for you at redline?
Old 03-03-12, 08:29 AM
DCoolBeans
DCoolBeans's Avatar
^ yes, you can rev it past till your motor blows up. The trans will not upshift for you, but it will downshift for you.
Old 03-03-12, 08:34 AM
xjason
xjason's Avatar
Damn, I hope i didn't do any damage to my engine. The other day I was driving, didn't realize it was in manual mode, went all the way to redline, then the exhaust was backfiring like crazy and felt like i was in limp mode.
Old 03-03-12, 08:43 AM
MisterSkiz
MisterSkiz's Avatar
Don't worry DCoolBeans was just joking.
When you hit redline in Manual Mode, the engine will not let you rev over it, you are fine.
Usually the problem that people have with "standard" manuals is that they downshift from 5th to 2nd while doing 80mph and mechanically over rev the motor, usually making the pistons kiss the valves, or causing the valves to float.
Your car is fine, just don't do that when the car is "cold".
Old 03-03-12, 10:04 AM
DCoolBeans
DCoolBeans's Avatar
Its not healthy but the car will protect itself from over reving it...cuts off the fuel
We don't have the downshifting problems in our cars like manuals do. The car is smarter than the human, it will not let you downshift to a lower gear if it will be close to redline
Old 03-29-12, 07:23 AM
Heather558
Heather558's Avatar
These cars are idiot proof. They are designed to last regardless how you should "attempt" to drive. Just the other day I put mine in manual mode and when I took off I was in 2nd, I got on it and went to shift only to find out that I shifted the wrong way (trying to go from 2nd to first) but like I said the car idiot proof . Mine didn't downshift. I only did that because my M3 with smg was opposite when shifting so I'm not use to the isf yet.
Old 03-29-12, 08:22 AM
VtotheJ
VtotheJ's Avatar
At redline it doesn't shift for you, I learned this when I went to redline for the first few times after purchasing the car. I was in 3rd gear and kept accelerating but it kept bouncing off the rev limiter. Took me a while getting used to 416hp coming from a 140hp Integra
Old 03-29-12, 11:57 AM
UCrazyKid
UCrazyKid's Avatar
What you perceived as a backfire was the car bumping against redline and the engine cutting fuel. You are fine.
Old 03-29-12, 12:35 PM
iH8RICERZ
iH8RICERZ's Avatar
Sounds like me... except I was coming from a 215 whp integra lol
Old 03-29-12, 06:55 PM
mugenh22a4
mugenh22a4's Avatar
What's manual mode?
pngo
03-15-19 08:34 PM
JT2MA71
RC F (2015-present)
06-06-17 09:44 AM
aritweets
06-17-16 06:26 PM
Sexis350
06-18-15 03:58 AM
Dtcsurfer
IS - 1st Gen (2001-2005)
05-23-13 04:16 AM
Quick Reply: Manual Mode
