Ejecting navigation disc without cutting power?
Old 04-29-13, 01:41 PM
Evil Teo
Evil Teo's Avatar
^^^if its the real disc you shouldn't be having a problem unless the disc is all scratched up...not sure if different gen matters.
Old 04-29-13, 02:18 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Dumardus - What year is your car?
Old 04-29-13, 11:18 PM
dumardus
dumardus's Avatar
It is real genuine dvd which came with car from US . My Car is 2008.
Old 04-30-13, 04:08 AM
rupavi
rupavi's Avatar
Originally Posted by dumardus
No, I did these steps
1 Remove the clock panel......OK
2.Eject the European-DVD - in my case because the "A program cannot be read"-screen by TAPPING the top left and top right corner repeadeadly.......OK
3.Insert US-DVD....(disk is original)
but my navigation unit didnt load the software from US-navigation disc.
Still On nav. screan is "A program cannot be read......"So I put US nav. disk in laptop and all disk files looks ok...
I have an imported ISF as well and have both the American Nav disc that came with the car and an original disc for this region, and i cannot seem to get this regions disc to work. I have attempted all the steps mentioned above and when I insert the middle eastern disc it says "Disc cannot be read"
As far as your problem is concerned, according to my knowledge, you have to do a system reboot so that the American disc loads the software. In order to do so, just remove the fuse labeled TV10 that's under the steering wheel and then switch the car on for a minute or so. switch the car off insert the fuse back and switch the car on you will get a loading screen on your nav screen. Don't switch the car off till it completes loading. Your nav screen functions will start working perfectly but you wont have any maps.
People have gotten different region discs to work on imported cars successfully, and I have read various forums regarding this matter. Apparently you have to modify certain files on the disc (I don't know which ones) to get the disc to read. I still haven't gotten mine to work. If you figure out a way for the European disc to work please let me know
Old 04-30-13, 11:07 AM
dumardus
dumardus's Avatar
Rupavi do you have two US. nav. discs? I have just this one US.
plus four for Europe. Maybe I do need another one?
Old 04-30-13, 12:24 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
This is a particularly old version of the firmware. It is possible you need a newer version if your European DVD is recent. I've seen compatibility issues with firmware and maps when trying to make hybrid DVDs.
Old 10-31-18, 10:14 AM
Arpadf189
Arpadf189's Avatar
Default Nav dvd reboot bootloop
I accidentally put a wrong dvd into the navigation system drive. When I touch aggre button the system restart and I cannot to eject the nav dvd. I have read the comments but the top right and bottom left method did not work for me. I do not understand what does clock panel mean. Could anyone help me how can I eject the nav dvd please? Thank you!
Torben
08-07-15 01:59 AM
defo
03-16-13 05:49 PM
JohnParks
01-20-11 04:55 PM
cnotes999
12-13-07 01:01 PM
Quick Reply: Ejecting navigation disc without cutting power?
