DIY Stock Intake Mod
Old 11-13-08, 05:56 PM
  #31
stick
stick's Avatar
Originally Posted by Juanca
Here are my answers:
1. I did the mod last Sunday and drove that way for about 250 miles before I went to the track.
2. My car is completely stock except for tints.
3. I did the mod just as you showed it on the first post, so it's confirmed, I used a vacuum cap.
As I said I thought my car was faster. When I went to the track 2 months ago the air temp was about 86F, so this last Wednesday I was expecting better times because of this mod, and also because air temp was 66F. Two months ago I was runing 8.6@85MPH in the 1/8 mile, and you can imagine my surprise when this week my best run out of the first 6 passes was 8.7@84MPH. I wondered if the mod had something to do with being slower when I should be faster (at least because of the cooler night), so I removed the cap and connected the hose back. I had another pass right away and bam! 8.47@86.5MPH. The following 5 passes were similar. This experience showed me that the mod doesn't help performance-wise.
20 degree difference in air temp.......good for intake air, bad for tire grip. The warmer day will have a hotter track and give better grip. Too many variables. I don't know if the mod works, but a more controlled environment is needed for testing.
Old 11-13-08, 06:33 PM
  #32
Juanca
Juanca's Avatar
This is why I posted times before and after the mod. I basically picked up 0.2s in the 1/8 mile after pluging the vacuum hose back. These runs where done one after the other, during the same night, so conditions were identical.
Old 11-13-08, 07:01 PM
  #33
Supraman16
Supraman16's Avatar
I think what Stick is trying to say is that the colder track makes traction a issue where the warmer track traction wasn't too big of a concern.
I believe this mod give improved low end torque. I say this because that's what it feels like to me. With the colder track, and the higher torque down low (once again, just an assumption), you get a tiny bit more wheel spin resulting in a lower ETA and MPH. Now in the stock setup, you have less torque down low and therefore less wheel spin...Darshana S...
Old 11-13-08, 10:31 PM
  #34
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Sorry, but MPH trumps all. Better MPH means the engine is making more power. End of story.
Old 11-14-08, 06:05 AM
  #35
Supraman16
Supraman16's Avatar
I believe this is only true when it's measured in the 1/4 mile, not the 1/8th mile...
Old 11-14-08, 06:22 AM
  #36
Juanca
Juanca's Avatar
I was going to say the same thing. My trap speed went up right away, so I knew I was making more power.
Old 12-28-08, 10:35 AM
  #37
hwy1isf
hwy1isf's Avatar
Any one ever do dyno runs with this mod?
Old 01-04-09, 06:16 AM
  #38
dana_daen
dana_daen's Avatar
where is this "actuator"?
Old 01-04-09, 06:22 AM
  #39
dana_daen
dana_daen's Avatar
nevermind I can tell where is by the photo
Old 07-10-11, 03:18 PM
  #40
CCJ22
CCJ22's Avatar
Anymore info on this mod?
Old 07-10-11, 07:29 PM
  #41
vraa
CL Folding Team Starter
vraa's Avatar
Yes see https://www.clublexus.com/forums/is-...ml#post6523617
Old 07-10-11, 08:08 PM
  #42
CCJ22
CCJ22's Avatar
Originally Posted by vraa
Thank you
Old 01-02-12, 01:21 PM
  #43
Super6
Super6's Avatar
Anybody done this long term? I just did for about 5 mile ride. I fear my car blowing up long term...
Old 01-17-12, 03:35 PM
  #44
ISFFF
ISFFF's Avatar
I look forward to trying it. I just need to find a vacuum cap first.
I really like the sound of the second intake. It is usually hard to reach to over 3,600 to get it to roar.
I think it's worth it to try it even if there's no HP gain. The sound alone is worth it.
Old 01-19-12, 11:15 AM
  #45
ISFFF
ISFFF's Avatar
I just bought today a set of vacum caps and I'm eager to try it on.
Quick Reply: DIY Stock Intake Mod
