Does your trunk pop open at all when you open it?
Tech Info Resource
Pops up nicely ever since replaced the struts. It was sagging even when open, so I replaced them with aftermarket. Now the trunk practically opens itself.
Hmmm........I guess I need to replace the struts then because mine doesn't pop up at all lol.........
neweyslex (12-15-16)
Tech Info Resource
Seller is in Vista, CA. I know exactly where that is. I used to drive almost there when I went to the Bay Area through the Sacramento Delta on the levee roads. What fun drives those were!
ISFHEMS (01-03-17)
Thanks everyone. I'm going to see if my dealer will replace under my extended warranty today. I have to go back and have them check my coolant again because my heater is blowing cold air again even after I filled up with distilled water. The level in the overflow looks the same since I filled it--guessing they left air in the system when they did the ELE recall???
mine opens ever so slightly...yeah new trunk supports should help.
another thing new to test is have your trunk open half way and see if the trunk stays open. you know you'll need new trunk supports if the trunk slams shut
