08 isf check vsc check engine and trac cont.
As title states check engine has came on along with check vsc and trac control cel. These are the codes being thrown...
Lexus Drivers
Service Service HistorySERVICE HISTORY FOR YOUR 2008 IS F
Get the most out of your Lexus Drivers account by keeping track of your vehicle service history. Work performed at an authorized Lexus Service Center will be added automatically. Any work done outside of a Lexus Service Center, can be updated or added yourself.Service History
SERVICE HISTORY FOR: 2008 IS FVIN: JTHBP262485003179
Filter History by Year
106361 miles
DATE: 09/10/2016Repair# 0195087
reported by: Lexus of Tampa Bay
Service: BATTERY TESTS WITHIN LEXUS SPECIFICATIONS AT THIS TIME.
description:
Service: BRAKE PADS ARE IN GOOD CONDITION AT THIS TIME.
description:
Service: CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT
description: CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~ ~CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~ ~ ~ ~106359 20 COMPLETED
Service: DECLINED A/C CABIN FILTER REPLACEMENT
description:
Service: DECLINED BRAKE FLUID EXCHANGE
description:
Service: DECLINED ENGINE AIR FILTER REPLACEMENT
description:
Service: DECLINED FUEL INDUCTION SERVICE
description:
Service: MISCELLANEOUS
description: MISCELLANEOUS ~ ~PRE PURCHASE INSPECTION ~ ~ ~ ~106359 100 COMPLETEDMISCELLANEOUS ~ ~CUSTOMER STATES CHECK FOR CRACKED MANIFOLD ~ ~ ~ ~106359 NO CRACKS FOUND AT THIS TIME. OPERATING AS DESIGNED. ADVISED GUEST THAT TO PERFORM A COMPLETE VISUAL INSPECTION WOULD REQUIRE MORE DIAG TIME TO ACCESS AND REMOVE HEAT SHIELDS, DECLINED.
Service: TIRES ARE IN GOOD CONDITION.
description:
144899 miles
DATE: 07/22/2016Repair# 0188071
Service: BATTERY
description: BATTERY ~ ~BATTERY FAILED TESTING. BATTERY RPL R0 108663 08/26/14 105,926 MILES ~ ~BATTERY CELL FAILURE ~ ~144897 60 REPLACED BATTERY AND INSPECTED CHARGING SYSTEM
Service: BATTERY COMB: BATTERY
description:
description: CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~ ~CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~ ~ ~ ~144897 20 PERFORMED INSPECTION
Service: INS PANEL SAFETY PAD SUBASSY
description: INS PANEL SAFETY PAD SUBASSY ~ ~CUSTOMER STATES THE DASH IS STICKY. ~ ~MATERIAL BREAKDOWN DUE TO EXTREME HEAT AND HUMIDITY ~ ~144897 200 REPLACED INSTRUMENT PAD SUB ASSY. LEXUS TO ASSIST W/REPAIR AS A ONETIME GOOWILL GESTURE IN PURSUIT OF CUSTOMER SATISFACTION
description: MISCELLANEOUS ~ ~CUSTOMER STATES THE PLASTIC AROUND SHIFT **** IS BROKEN. PLEASE ADVISE ~ ~ ~ ~144897 20 REPLACED SHIFTERMISCELLANEOUS ~ ~CUSTOMER STATES THE LEFT FRONT PARKING SENSOR IS BROKEN PLEASE ADVISE ~ ~ ~ ~144897 200 REPLACED PARKING SENSORMISCELLANEOUS ~ ~CUSTOMER WOULD LIKE WHEELS TO BE LOOKED AT TO RE-FINISHED. ~ ~
119673 miles
DATE: 04/27/2015Repair# 0134928
Service: ELE-INSP FAN/REPL SCREWS
description: ELE-INSP FAN/REPL SCREWS ~ ~OUTSTANDING SERVICE CAMPAIGN***ELE*** ~ ~. ~ ~119661 CAMPAING ELE AGGB3A 130 INSPECT AND REPLACE THE COOLING FAN MOTOR SCREWS (INSPECTION PASS
Service: ELF-REPL FUEL PRESSURE GASKE T-IS F,GS460,LS460,LS600H
description: ELF-REPL FUEL PRESSURE GASKE T-IS F,GS460,LS460,LS600H ~ ~OUTSTANDING SERVICE CAMPAIGN***ELF*** ~ ~. ~ ~119661 CAMPAING ELF AGGB7B 410 REPLACE THE FUEL PRESSURE SENSOR GASKET
Service: MOVED TO: 134928C LINE: A
description: MOVED TO: 134928C LINE: A ~ ~MOVED TO: 134928C LINE: A ~ ~
Service: MOVED TO: 134928C LINE: B
description: MOVED TO: 134928C LINE: B ~ ~MOVED TO: 134928C LINE: B ~ ~
Service: MOVED TO: 134928C LINE: C
description: MOVED TO: 134928C LINE: C ~ ~MOVED TO: 134928C LINE: C ~ ~
Service: MOVED TO: 134928C LINE: D
description: MOVED TO: 134928C LINE: D ~ ~MOVED TO: 134928C LINE: D ~ ~
Service: MOVED TO: 134928C LINE: E
description: MOVED TO: 134928C LINE: E ~ ~MOVED TO: 134928C LINE: E ~ ~
Service: MOVED TO: 134928C LINE: F
description: MOVED TO: 134928C LINE: F ~ ~MOVED TO: 134928C LINE: F ~ ~
Service: MOVED TO: 134928C LINE: G
description: MOVED TO: 134928C LINE: G ~ ~MOVED TO: 134928C LINE: G ~ ~
Service: MOVED TO: 134928C LINE: H
description: MOVED TO: 134928C LINE: H ~ ~MOVED TO: 134928C LINE: H ~ ~
Service: MOVED TO: 134928C LINE: I
description: MOVED TO: 134928C LINE: I ~ ~MOVED TO: 134928C LINE: I ~ ~
119673 miles
DATE: 04/24/2015Repair# 134928C
description:
Service: BRAKE FLUID EXCHANGE
description: BRAKE FLUID EXCHANGE ~ ~BRAKE FLUID EXCHANGE ~ ~ ~ ~119661 100 PERFORM BRAKE FLUSH
description:
description: MISCELLANEOUS ~ ~GUEST STATES TRUNK SWITCH IS MELTING.ADVISE ~ ~ ~ ~119661 100 REPLACE TRUNK SWITCHMISCELLANEOUS ~ ~GUEST STATES THAT WHEN GOING OVER BUMPS CAR RATTLES.ADVISE ~ ~ ~ ~119661 ROAD TEST CAR NO RATTLE NOISE FOUND ALL SUSPENSION COMPONENTS WORKING NORMAL NO LEAKS FROM STRUTS
Service: PENNZOIL 5W30 OIL CHANGE
description: PENNZOIL 5W30 OIL CHANGE ~ ~PENNZOIL 5W30 OIL CHANGE ~ ~ ~ ~119661 40 PERFORM LOF
Service: REPLACE AIRCONDITIONING FILTER
description: REPLACE AIRCONDITIONING FILTER ~ ~REPLACE AIRCONDITIONING FILTER ~ ~ ~ ~119661 30 REPLACE A/C FILTER
Service: REPLACE ENGINE AIR FILTER
description: REPLACE ENGINE AIR FILTER ~ ~REPLACE ENGINE AIR FILTER ~ ~ ~ ~119661 30 REPLACE AIR FILTER
Service: REPLACE WIPER INSERTS
description: REPLACE WIPER INSERTS ~ ~REPLACE WIPER INSERTS ~ ~ ~ ~119661 20 REPLACE WIPER BLADES
description:
Service: TRANSFER CASE/DIFFERENTIAL SERVICE
description: TRANSFER CASE/DIFFERENTIAL SERVICE ~ ~TRANSFER CASE/DIFFERENTIAL SERVICE ~ ~ ~ ~119661 50 PERFORM DIFF SERV
105926 miles
DATE: 08/26/2014Repair# 0108663
description:
description:
description: MISCELLANEOUS ~ ~C/S THAT HE THINK THE SHOCKS ARE WEARING OUT, VEHICLE DOESNT FEEL AS STIFF AS IT USED TO, PLEASE ADVISE ~ ~ ~ ~105925 COULD NOT CONFIRM CUSTOMER CONCERN AT THIS TIME TEST DROVE VEHICLE AND PERFROMED JOUNCE TEST. VEHICLE PERFORMS AS DESIGNED, COULD NOT CONFIRM THAT SHOCK ARE SOFT OR WORN. NO VISIBLE LEAKS FOUND AND DURING TEST DRIVE, FEELS STIFF. DID PROVIDE QUOTE
Service: MISCELLANEOUS ELECTRICAL
description: MISCELLANEOUS ELECTRICAL ~ ~GUEST STATES TO PLEASE TEST BATTERY, ALSO, THE BATTERY COVER IS IN THE TRUNK, PLEASE RE-INSTALL ~ ~ ~ ~105925 PROVIDED ESTIMATE
Service: PENNZOIL GOLD SYNETHIC BLEND - OIL CHANGE
description: PENNZOIL GOLD SYNETHIC BLEND - OIL CHANGE ~ ~PENNZOIL GOLD SYNETHIC BLEND - OIL CHANGE ~ ~ ~ ~105925 40
Service: REPLACE BATTERY,RETIME WINDOWS IF NEEDED, SET RADIO STATIONS
description: REPLACE BATTERY,RETIME WINDOWS IF NEEDED, SET RADIO STATIONS ~ ~REPLACE BATTERY,RETIME WINDOWS IF NEEDED, SET RADIO STATIONS ~ ~
description:
93203 miles
DATE: 01/14/2014Repair# 0084656
Service: ALIGNMENT, WHEEL - FOUR - ADJUST
description: ALIGNMENT, WHEEL - FOUR - ADJUST ~ ~ALIGNMENT, WHEEL - FOUR - ADJUST ~ ~ ~ ~93201 150 PERFORM FOUR WHEEL ALIGNMENT COMPLETE.
description:
Service: FUEL INDUCTION / THROTTLE BODY SERVICE
description: FUEL INDUCTION / THROTTLE BODY SERVICE ~ ~FUEL INDUCTION / THROTTLE BODY SERVICE ~ ~ ~ ~90200 INDUCTION SERVICE 100
description: MISCELLANEOUS ~ ~GUEST STATES THAT HIS SUNROOF WILL RATTLE WHEN DRIVING ON ROUGH ROADS OR GOING OVER SPEED BUMPS ~ ~ ~ ~90200 PROVIDED ESTAMATE CUSTOMER DECLINEDMISCELLANEOUS ~ ~GUEST STATES THAT HIS REAR SPOILER MAY NEED TO BE PAINTED, ADVISE. ~ ~MISCELLANEOUS ~ ~ALIGNMENT CHECK ~ ~
description: MISCELLANEOUS ELECTRICAL ~ ~SEAT LUMBAR ISNT WORKING. GUEST DIDNT STATE WHICH ONE. ~ ~ ~ ~90200 DECLINE
Service: TIRE
description: TIRE ~ ~GUEST STATES THAT THE VEHICLE STARTS TO SHAKE BETWEEN 60-70MPH, THINKS IT MAY BE FROM THE RIGHT FRONT ~ ~ ~ ~90200 VEHICLE HAS 3 BENT RIMS
description:
Service: WHEEL - BALANCE OFF-VEHICLE
description: WHEEL - BALANCE OFF-VEHICLE ~ ~WHEEL - BALANCE OFF-VEHICLE ~ ~ ~ ~90200 BALANCE 120
85572 miles
DATE: 08/14/2013Repair# 0420895
reported by:
Service: FOUR WHEEL ALIGNMENT, CHECK TIRE WEAR, CONDITION AND TREAD DEPTH, CHECK TIRE PRE
description: FOUR WHEEL ALIGNMENT, CHECK TIRE WEAR, CONDITION AND TREAD DEPTH, CHECK TIRE PRE ~ ~FOUR WHEEL ALIGNMENT, CHECK TIRE WEAR, CONDITION AND TREAD DEPTH, CHECK TIRE PRESSURES AND TEST DRIVE $139.95
Service: GERMAIN LEXUS PLATINUM CLUB******CHANGE OIL AND FILTER
description: GERMAIN LEXUS PLATINUM CLUB******CHANGE OIL AND FILTER ~ ~GERMAIN LEXUS PLATINUM CLUB******CHANGE OIL AND FILTER
Service: REMOVED PIECE UNABLE TO SECURE
description: REMOVED PIECE UNABLE TO SECURE ~ ~PLEASE CHECK SPLASH SHIELD HANGING DOWN
Service: REPLACE AND MOUNT AND BALANCE 4 TIRES
description: REPLACE AND MOUNT AND BALANCE 4 TIRES ~ ~MOUNT AND BALANCE ALL 4 TIRES RESET TIRE MONITORING SYSTEM (IF APPLICABLE) TEST DRIVE FOR PERFORMANCE $99.95
Service: REPLACE REAR BRAKE PADS AND RESURFACE ROTORS, TEST BRAKE SYSTEM FOR PERFORMANCE
description: REPLACE REAR BRAKE PADS AND RESURFACE ROTORS, TEST BRAKE SYSTEM FOR PERFORMANCE ~ ~REPLACE REAR BRAKE PADS AND RESURFACE ROTORS, TEST BRAKE SYSTEM FOR PERFORMANCE AND TEST DRIVE $$349.95.
Service: REPLACED WATER PUMP
description: REPLACED WATER PUMP ~ ~WATER PUMP LEAKING
82990 miles
DATE: 06/26/2013Repair# 0065461
description:
Service: BRAKE PADS ARE IN NEED OF REPLACEMENT SOON.
description:
Service: COMPLETE DETAIL, WASH VEHICLE, WASH ALL DOOR JAMBS, CLAY EXTERIOR, BUFF AND POLI
description: COMPLETE DETAIL, WASH VEHICLE, WASH ALL DOOR JAMBS, CLAY EXTERIOR, BUFF AND POLI ~ ~COMPLETE DETAIL, WASH VEHICLE, WASH ALL DOOR JAMBS, CLAY EXTERIOR, BUFF AND POLISH, WAX VEHICLE, CLEAN WHEELS, SHAMPOO CARPETING AND SEATS, CLEAN HEADLINER, DASH, AND WINDOWS
description: CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~ ~CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~ ~.
Service: EVENTUAL NEW TIRES WILL HELP THIS ISSUE
description: EVENTUAL NEW TIRES WILL HELP THIS ISSUE ~ ~OWNER REPORTS: THE VEHICLE SEEMS TO PULL TO THE RIGHT, TIRES ARE NEWISH-ADVISE ON ALIGNMENT ~ ~ ~ ~82990 FRONT TIRES HAVE UNEVEN TREAD WEAR. L/F IS 8/32 AND R/F IS 6/32 CAUSING PULL TO RIGHT.
Service: OK AT THIS TIME
description: OK AT THIS TIME ~ ~OWNER REPORTS THE BATTERY WAS INSTALLED AND DOESNT FIT PROPERLY-ADVISE ~ ~ ~ ~82990 AFTERMARKET BATTERY IS DIFFERENT SIZE FROM FACTORY. FOUND LOOSE. TIGHTENED BATTERY TIE DOWN.
Service: PROVIDE LOANER VEHICLE. GUEST IS RESPONSIBLE FOR FUEL USED, ANY DAMAGE, AND ANY
description: PROVIDE LOANER VEHICLE. GUEST IS RESPONSIBLE FOR FUEL USED, ANY DAMAGE, AND ANY ~ ~PROVIDE LOANER VEHICLE. GUEST IS RESPONSIBLE FOR FUEL USED, ANY DAMAGE, AND ANY VIOLATIONS WHILE IN THE GUEST'S POSSESSION. A $90.00 A DAY CHARGE WILL BE APPLIED FOR LOANERS NOT RETURNED WITHIN 12 HOURS OF COMPLETION OF GUEST'S VEHICLE
Service: REMOVE SERRATION PATTERN & INSTALL NEW WIPER ARM NUTS
description: REMOVE SERRATION PATTERN & INSTALL NEW WIPER ARM NUTS ~ ~COMPLETE RECALL DLA-WIPER ARM NUT ~ ~. ~ ~82990 DLA SS COMPLETED 3524AA 060
Service: REPLACE INTERNAL TRUNK RELEASE LEVER
description: REPLACE INTERNAL TRUNK RELEASE LEVER ~ ~OWNER REPORTS: THE DLB RECALL IS DUE-TRUNK LATCH ~ ~. ~ ~82990 DLB SSC COMPLETED 3611AA 030
Service: REPLACED THE WINDSHILED SIDE RUBBER TRIMS
description: REPLACED THE WINDSHILED SIDE RUBBER TRIMS ~ ~OWNER REPORTS: THE SIDE WINDHIELD RUBBER MOLDINGS ARE CRACKING AND POSSIBLY WISTLING-ADVISE ~ ~ ~ ~82990 REPLACED BOTH WINDSHIELD MOLDINGS. 100
description:
Service: TWEATER IS DISTORTED, MUST REMOVE ENTIRE PACKAGE TRAY TO GET TO IT, ESTI,ATE TO
description: TWEATER IS DISTORTED, MUST REMOVE ENTIRE PACKAGE TRAY TO GET TO IT, ESTI,ATE TO ~ ~OWNER REPORTS: THE SPEAKER IN THE REAR DECK LID SOUNDS DISTORTED-ADVISE ~ ~ ~ ~82990 FOUND R/R PACKAGE TRAY SMALL SPEAKER DISTORED. REMOVED AND REPLACED R/R PACKAGE TRAY SMALL SPEAKER. 250
71743 miles
DATE: 11/23/2012Repair# 0993661
Service: ADJUSTED PART FOR NOW
description: ADJUSTED PART FOR NOW ~ ~OWNER REPORTS: THE DRIVERS SIDE FRONT INNER A-PILLARE IS LOOSE-ADVISE ~ ~ ~ ~71743 CST DECLINED TO REPLACE ""A"" PILLAR AT THIS TIME
Service: COMPLETED
description: COMPLETED ~ ~PROVIDE AN EXTRA BATTERY IN THE CUPHOLDER FOR THE 2ND REMOTE ~ ~ ~ ~71743 COMPLETED
description: CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~ ~CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~ ~ ~ ~71743 PERFORMED AN INSPECTION
Service: CUSTOMER SATISFACTION DISCOUNT
description:
Service: FLUSHED, SEE LOWER LINES
description: FLUSHED, SEE LOWER LINES ~ ~OWNER REQUESTS: THE BRAKE AND COOLANT FLUIDS CHECKED ~ ~ ~ ~71743 PERFORMED AN INSPECTION
description: MISCELLANEOUS ~ ~DENT BUSTERS TO LOOK AT DENT ON THE ROOF NEAR SHARK FIN ANTENNAMISCELLANEOUS ~ ~GLENNS TO ADVISE COST TO REFINISH ALL THE WHEELS THAT ARE SCRATCHEDMISCELLANEOUS ~ ~DETAIL TO REFINISH THE FRONT HEADLIGHTSMISCELLANEOUS ~ ~BODYSHOP TO ADVISE COSTS ON: HOOD CHIPS, FRONT BUMPER CHIPS/BUG DAMAGE, REAR BUMPER COVER DAMAGE, TRUNK EDGE SCRATCHES-SEE NICK ON ALLMISCELLANEOUS ~ ~OWNER REPORTS: THE OUTER FRONT A-PILLARE TRIMS ARE SPLITTING AND THE RUBBER LOOKS OLD-ADVISE COST TO REPLACE ~ ~ ~ ~71743 CST SECLINED TO REPLACED WINDSHIELD MOULDING AT THIS TIMEMISCELLANEOUS ~ ~OWNER REPORTS: THE TRUNK BUTTON HAS FALLEN OFF-ADVISE ON REPLACEMENT ~ ~ ~ ~71743 CST DECLINED TO REPLACED TRUNK SWITCH AT THIS TIME
Service: PERFORM BRAKE FLUID EXCHANGE SERVICE
description: PERFORM BRAKE FLUID EXCHANGE SERVICE ~ ~PERFORM BRAKE FLUID EXCHANGE SERVICE ~ ~ ~ ~71743 100 PERFORMED BRAKES FLUSH
Service: PERFROM COOLING SYSTEM FLUID EXCHANGE
description: PERFROM COOLING SYSTEM FLUID EXCHANGE ~ ~PERFROM COOLING SYSTEM FLUID EXCHANGE ~ ~ ~ ~71743 100 PERFORMED COOLANT FLUSH
Service: RECOMMENDED 15K SERVICE, SEE MENU FOR DETAILS
description: RECOMMENDED 15K SERVICE, SEE MENU FOR DETAILS ~ ~RECOMMENDED 15K SERVICE, SEE MENU FOR DETAILS ~ ~ ~ ~71743 190 PERFORMED 15K SERVICE
30008 miles
DATE: 06/11/2010Repair# 0908095
Service: 9LG REPL PEDAL PAD, REFLASH, AWFM - IS MODELS ONLY
description: 9LG REPL PEDAL PAD, REFLASH, AWFM - IS MODELS ONLY ~ ~FLOOR MAT INTERFERENCE CAMPAIGN ~ ~. ~ ~30008 RECALL 9915M5 120 PERFORMED 9LG
Service: CAR 30000 MILE INTERVAL SERVICE - SEE MENU FOR DETAILS
description: CAR 30000 MILE INTERVAL SERVICE - SEE MENU FOR DETAILS ~ ~CAR 30000 MILE INTERVAL SERVICE - SEE MENU FOR DETAILS ~ ~ ~ ~30008 REQUEST 490 PERFORMED 30000 MILE SERVICE
description: CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~ ~CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~ ~ ~ ~30008 PERFORMED INSPECTION
description: MISCELLANEOUS ~ ~SEE HISTORY VEHICLE IS NOT PERFORMING AS IT SHOULD LAST TIME CLEANED THE PERFORMANCE VALVE ~ ~ ~ ~30008 TEST DROVE NORMAL RESET ECU
23330 miles
DATE: 12/30/2009Repair# 0891963
description:
description: CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~ ~CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISITCUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~ ~CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT
description: MISCELLANEOUS ~ ~CUSTOMER STATES THAT THE VEHICLE DOES NOT ACCEL/ SEEMS LIKE LESS TORQUE/ NOT AS FAST ~ ~. ~ ~23330 RESET ECU RESET ECU
Service: OIL CHANGE SERVICE. CHANGE OIL AND FILTER, TOP OFF ALL FLUIDS, CHECK & ADJUST TI
description: OIL CHANGE SERVICE. CHANGE OIL AND FILTER, TOP OFF ALL FLUIDS, CHECK & ADJUST TI ~ ~OIL CHANGE SERVICE. CHANGE OIL AND FILTER, TOP OFF ALL FLUIDS, CHECK & ADJUST TIRE PRESSURE, CAR WASH. $49.95 PLUS TAX. ~ ~ ~ ~23330 40 COMPLETED LOF
Service: RECOMMENDED ON NEXT SERVICE AIR FILTER, COOLANT FLUSH, BRAKE FLUSH
description:
Service: TIRES ARE IN NEED OF REPLACEMENT SOON.
description:
17748 miles
DATE: 07/31/2009Repair# 0877906
Service: 27 POINT COURTESY INSPECTION, SERVICE DRIVE WALK AROUND, REVIEW MAINTENANCE SCHE
description: 27 POINT COURTESY INSPECTION, SERVICE DRIVE WALK AROUND, REVIEW MAINTENANCE SCHE ~ ~27 POINT COURTESY INSPECTION, SERVICE DRIVE WALK AROUND, REVIEW MAINTENANCE SCHEDULE
Service: CAR 15000 MILE INTERVAL SERVICE - SEE MENU FOR DETAILS
description: CAR 15000 MILE INTERVAL SERVICE - SEE MENU FOR DETAILS ~ ~CAR 15000 MILE INTERVAL SERVICE - SEE MENU FOR DETAILS ~ ~ ~ ~15000 260 COMPLETED 15K
Service: CUSTOMER STATESPLASTIC COMING AROUND THE LEFT FRONT WHEEL
description: CUSTOMER STATESPLASTIC COMING AROUND THE LEFT FRONT WHEEL ~ ~CUST STATES PLASTIC PIECE IN L/R FENDERWELL HAS BECOME DETACHED ~ ~ ~ ~17417 000 PUSH PIN FELL OFF, REPLACED AND REINSTALLED PART.
4599 miles
DATE: 10/06/2008Repair# 0849204
Service: 5,000 MILE SERVICE
description: 5,000 MILE SERVICE ~ ~5000 MILE NEW VEHICLE SERVICE 8 CYL. MODELS. INCLUDES CHANGE ENGINE OIL AND FILTER, ROTATE TIRES AND ADJUST TIRE PRESSURES AS NECESSARY. ~ ~. ~ ~4599 5K 60
Service: INSTALLED XM RADIO
description: INSTALLED XM RADIO ~ ~IN STALL XM RADIO ~ ~ ~ ~4599 INSTALLED XM RADIO 200
11 miles
DATE: 06/25/2008Repair# 0595356
reported by:
Service: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
description: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~ ~PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~ ~F
Terms and conditions
About Lexus
FINANCE & LEASING
Brand & Lifestyle
Service
© 2006-2016 Lexus, a Division of Toyota Motor Sales, U.S.A., Inc. All information contained herein applies to U.S. vehicles only.
nch2oracer
05-11-10 01:37 PM
