Rear axle lateral play?
Like many others I am getting some noise from a rear axle, the passenger side in my case. As you can see in the video I am getting quite a bit of lateral play. The axle nut seems to have the original punch mark indicating that it has not moved. Any ideas?
Some lateral play is normal due to the fact that as the suspension moves the distance between the wheel and differential carrier changes and the axle has to be able to adjust to those changes.
The rust could be an indicator that the splines need to be greased. I have an 08 with less then 50k miles and am having the same issue. I ordered 2 new axle nuts and will be greasing both splines. Never noticed the sound until I got my PSS tires.
Streamline
Suspension and Brakes
04-19-06 06:19 AM
