New ISF owner - 2008 - trunk interior is really hot
Did a drive across town tonight typically going 35-45mph most of the way - about 30-40 minutes. sat in a drive thru for 5 minutes. Its about 89 tonight outside.
When I got home I removed some things from the trunk, and noticed it is really hot in there. The heat seems to be soaking in from the mufflers. Any thoughts on this?
Thanks!
Thanks!
I havent noticed it being extremely hot in mine, just warmish on hot days. Even if it does get a bit warm back there i can't see it causing much trouble, really isn't anything to get damaged by heat besides the small plastic trim pieces.
hoping some others can chime in on this. never owned a vehicle who's trunk interior got this warm.
Like I said I've experienced a little bit of this and am curious what other people have to say about it, I personally wouldn't worry about it much. There was a thread recently about the vents leading into the trunk being worn out quickly, you could check those out if its really an issue.
will order some new ones, see if that helps. I would assume it would.
mine is extremely hot almost all the time in sunny soCal, but i removed all the mat, tools and tires to shed weight..that probably has something to do with it. It's interesting to hear about your concern for exhaust restriction, never thought about that
Yup mine is also like that..
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
ShadowISF
12
09-17-12 02:30 PM
