ISF BBS wheels help
ISF BBS wheels help
Hello everyone...
Regarding the bbs 19in alloys I wanted to ask and find out if all 4 alloys are the same size? Meaning if the shop fitted them wrong and not on each corner as intended by bbs...
I ask because after a refub on a repaint the wheels 'fan blade design' on 3 wheels is facing backwards rather than frontwards...
Any help is appreciate
Thanks
Thanks
Hello everyone...
Thanks
Thanks
The stamping on the inside is proof, as RSXiMUS referenced to. It would be a bit weird if only one was showing a different direction. There were a few replicas out there and they were in the opposite direction of the BBS design. All four are not the same size. The front two have an 8.0 width, while the rears are 9.0.
Thank you guys for replying...
I will be getting them changed asap
Also if you guys and anyone knows what is the best tyre setup on the fan blade 19inch designs?
I currently have 225/40/19 front and rear are 255/35/19, but I hear later isf's tyre setup had wider rear fitments?
tronim (02-21-19)
For the 2012+ ISF OEM rims, there is no specific location like Rear RIght, Rear left, etc. correct?
I just looked at mine on the car.... I could not see anything looking around the barrel of the wheel. May not be looking in the right place though. My wheels are pretty dirty though..
Received 1,064 Likes
From 2008 to 2009 -> You can find the markings on ONE of the inner blades.. See my post from 2011..
There are no stupid question here...
If he still has OEM tires, then no as they are NOT directional. Which means they don't have an arrow pointing with specific tire rotation direction.
He will have to check and see what kind of tires he has on there.
For you, all you have to do is tell the shop which wheel belongs where...
All 2008 & 2009 wheels are clearly stamped on each wheel.
On One of the inside Blades Like so:
FL - FR - RL - RR
Beware of the excessive Brake Dust that can easily cover up the markings.....
Regards,
~ Joe Z
Forum Administrator
Our forum search isn't working right now so googling... not finding anything specific on 2012 that way
https://www.clublexus.com/forums/is-...im-weight.html
https://www.clublexus.com/forums/is-...el-weight.html
https://www.clublexus.com/forums/is-...eb-wheels.html
They weigh roughly the same as the narrower bbs wheels. I think 23 and 27 pounds.
Tech Info Resource
msgs350 (02-19-19)
