ISF PPE Header VS m3 JB4
Old 02-26-16, 12:19 PM
  #46
tgui
tgui's Avatar
Originally Posted by Max16
if you're talking to me, I did the job myself. I needed to drop the entire subframe. No way I could install them with just lowering it. I have sikky's but they are probably the same size as PPE
Did you get an alignment afterwards?
Old 02-26-16, 12:25 PM
  #47
ISFPOWER
ISFPOWER's Avatar
you can mark before you drop it but i would get an alignment.
Old 02-26-16, 12:40 PM
  #48
ISF350
ISF350's Avatar
Damn, I need to think about get an older cheaper 08/09 under $30k car then add this header better than buy a $40k+ newer 11/12 model
Old 02-26-16, 12:41 PM
  #49
STLblueF
STLblueF's Avatar
I marked my subframe before I dropped it and had the alignment checked afterwards and it was perfectly fine, no adjustments needed. Having said that, I'd still get it checked just to be sure.
Old 02-26-16, 12:46 PM
  #50
Max16
Max16's Avatar
No because I did it over the winter but that's the first thing when my car comes out.
You have no choice to do it even if you just lower the subframe. Even with marking the subframe you could be slightly off. I wouldn't cheap on 50$
Old 02-26-16, 05:58 PM
  #51
tgui
tgui's Avatar
Of course. I wasn't sure if there was a trick though.
My winter truck is in pieces, the ISF has snow tires. WTF. Great planning on my part. I had HOPED to have had the winter for car mods. Sigh.
Old 02-26-16, 07:22 PM
  #52
k20trick
k20trick's Avatar
The only thing that the installer did for me was mark the steering and paid real close attention to the way he put it back. The other stuff he did not mess with and no alignment was needed. Whoever said $50 alignment needs to refer me to them. Lexus charges minimum $150 for alignment and I just had mine couple months ago.
Old 02-26-16, 07:30 PM
  #53
STLblueF
STLblueF's Avatar
$150 is very high considering only front and rear toe is adjustable. My Lexus dealer does it for $99 with a coupon and that still seems high. There isn't more than 20 minutes involved in aligning an isf unless you have adjustable aftermarket camber kits.
Old 02-26-16, 07:37 PM
  #54
k20trick
k20trick's Avatar
I dont have that coupon and $150 is the going rate here. My dealer actually gave me brand new bridgestones and aligned the car right before buying. Regardless, Eman at NA Peformance did my install without needing an alignment so money saved right there and the headache to go get an alignment.
SaintNexus
04-22-11 07:23 PM
INHOCJP
04-30-08 01:33 PM
kyang91
04-29-08 03:22 PM
nighthawk
08-21-07 03:13 PM
Lexwang07
03-17-07 02:49 PM
Quick Reply: ISF PPE Header VS m3 JB4
