RCF strut tower brace on an ISF?
Old 12-06-15, 05:23 PM
Gearbangin
Gearbangin's Avatar
Sounds good. If I get time I'll try to get installed sooner. I was kind of shocked it mocked up so close as is.
Old 12-06-15, 06:59 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
So the bracket at the firewall is not mounted because the studs in the RC F's firewall are not present in the F. Do we have anything there we could mount a bracket on? Maybe the one piece is a custom bracket for the F with all the other parts being OEM Lexus?
WhyHateTho (12-01-21)
Old 12-06-15, 07:29 PM
j3ff
j3ff's Avatar
Originally Posted by Gearbangin
Ouch next time I won't share. Sorry guys.
We appreciate all the hard work sourcing and test fitting! It's always nice to have someone be the Guinea pig.
Hope you do keep sharing your progress!
Old 12-06-15, 09:48 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Lightbulb
Yes that's correct we lack studs and reinforcement..
I was looking at the photos some more and he actually needs to flip the oreintation of the firewall bracket to match the RC F.
It is actually marked for L & R installation... Also the Bar tabs are marked L & R too.
Close up on RC F I have on file. The firewall bar is NOT symmetrical..
See below..
Joe Z
Old 12-07-15, 07:44 AM
Gearbangin
Gearbangin's Avatar
Thanks for the pics. I did get some new tools over the weekend for mt Bday so maybe this weekend.
Old 12-07-15, 11:34 AM
lorenr
lorenr's Avatar
I like this whole idea of a strut reinforcement. Then again maybe it is not needed.
One option is to fabricate the bracket that attaches to the firewall. It looks as though there are two 2" X 2" plates attached (or welded) to the firewall on the RCF with a stud centered on each for the bracket. The two plates probably provide enough firewall support. If designed correctly the whole gismo should fit.
The engine cover may be an issue?
Loren
Old 12-07-15, 05:55 PM
FNSSESPORT
FNSSESPORT's Avatar
I second this, really appreciate you trying this out. If this can be made to work I think Lexus is going to owe you some commissions because I have a feeling a fair number of people would do this.
-R
Old 10-16-16, 03:46 PM
5280ISF
5280ISF's Avatar
@Gearbangin, did you ever mount the RC-F shock tower brace?
Old 10-19-16, 07:45 AM
Justin727
Justin727's Avatar
on a similar note this winter I may end up rerouting some of the wiring and modules on top of the intake manifold to clean it up some. If I am successful with this and depending on what's left still covering the intake manifold once complete I may end up removing the manifold to have it polished.
I'll start a thread if and when I start this project.
Old 10-20-16, 08:30 AM
Gearbangin
Gearbangin's Avatar
No gave up would require too much modification. Went this way and posted more pics in a separate thread.
josephx66
06-17-18 07:48 PM
IS-Fly168
IS F (2008-2014)
36
09-30-15 08:42 AM
meade916
IS F (2008-2014)
30
01-03-12 11:35 PM
AAD
12-05-10 02:13 PM
Quick Reply: RCF strut tower brace on an ISF?
