Joez Exhaust Question
Hey guys, first thing i gotta say is the JoeZ exhaust sounds great on the ISF and that videos certainly do not do the car any justice. I've searched and didn't find any answers to an issue i am having and wanted to see if you guys had any insights to a solution.
First week - two weeks i had the exhaust installed @ a mechanic with a lift, car had no problems and sounded perfect.
Now i'm about 3 weeks to a month in of having the exhaust and noticed something off. ONLY in automatic, not in manual mode.
As i let off the gas and the car is decelerating from engine braking (happens around 35-25mph), the car would make a slight knock/plastic sounding pop noise that sounds like it's from underneath the car if i gas again while the rpm's are dropping (during the engine brake). It sounds almost like if a wooden ball rolls on a floor and then stops when it knocks into a wall, that's what i can closely compare it to. Pretty much as the car is slowing down and the rpms go from about 1.3k > 1k and i gas at 1k while the car is humming from engine braking it could produce this sound. That is the only way i can produce the sound, regular acceleration and everything else is ok. Also do notice that the car drones pretty annoyingly more than it was initially but since everybody says there's a drone around 2k so i could be just paranoid.
I'm guessing it's a gasket leak probably from the exhaust and was planning to take it back to my mechanic to have it inspected while it's on a lift but just wanted to see if anybody else has had this problem before. Would a gasket leak cause the car to drone a bit more in the cabin? I hope i didn't repeat myself too much and thanks in advance!
I'm pretty sure I know what "popping" sound your referring to. In short, it's completely normal. It comes with the territory of owning an aftermarket exhaust. The only way to get rid of it is 1. Return to stock exhaust 2. In some instances you can have a tuner, tune out the sound. Being that our platform doesn't having any tuning solutions, your just gonna have to live with the raw sound it provides. Honestly, when I had straight pipes on my F, I loved that sound. No worries though, your car is fine.
I don't consider that a problem. Those who have been in my car love that sound actually. A deceleration and then thump gets the ears ready for a really nice deep lingering acceleration tone shortly after. I like to think of it similarly to shifting in a manual car. That change in between gears with an aftermarket exhaust will produce something very close to what you're experiencing.
I drive my car and intentionally shift so as to hear this as much as possible. Try this: accelerate at about 50 perfect in first gear up to around 2800 rpm, hit the upshift paddle then immediately take ur foot off the gas. You should hear a Symphony of glorious pops and crackles.
Also.. If it's a single thud noise.. I get that as well when slowing down in manual and auto.. At about 1300 rpm there is a single thud/low pop noise that happens pretty consistently. (also something I look forward too)
Man I remember when I first got it I was like WTF was that , and now I actually like it. It just sounds mean . Like she growls and then gurgles . Totally normal, thankfully.
