Vacuum leak sound at 1500rpm
Old 02-23-16, 10:37 PM
F_Throttle
F_Throttle's Avatar
Default Vacuum leak sound at 1500rpm (Fixed: pulley tensioner)
Usually after i run the car in manual/sport mode, I begin to hear a high-pitched 'hissing/whistling' noise coming from the engine. It sounds like a vacuum leak. It is audible while driving with the windows down.
I am having problems pin pointing the source, but it sounds like its coming from the center block. Can anyone point me in the right direction to the leak? It starts exactly at 1500 and cuts off at 2200 rpm (while in gear). 1500 to 3000 rpm while in park..
ps. I have a Takeda intake installed and I re-tighten the fittings.
Old 02-29-16, 12:33 PM
kzlflash
kzlflash's Avatar
Bumping this cause I seem to be hearing the same from my car. I've noticed it ever since I had my headers installed (no idea if that can even cause the suction noise, but I noticed it right after I got my car back from the header install). I assumed it was normal and never brought up the subject, but curious to see if anyone else is getting the same noise.. I also have an aFe drop in filter but I definitely had the noise before I switched from the oem filter.
Old 02-29-16, 01:27 PM
F_Throttle
F_Throttle's Avatar
I am reverting back to the stock airbox to isolate it.. But its more of a whistling noise than a suction.
Old 06-27-16, 01:11 PM
F_Throttle
F_Throttle's Avatar
Still having the issue, and the dealer can't replicate it - to recommend any action. I switched back to the stock airbox and nothing changed. My hearing is not as precise, but I think I've localized it towards the firewall (offset to the passenger side).
Here;s a video of what it sounds like.
Old 06-27-16, 01:19 PM
MileHIFcar
MileHIFcar's Avatar
No video/link not working.......
Old 06-27-16, 01:30 PM
sedition
sedition's Avatar
Sounds like something on one of the belts...have you checked the belt tensioner/accessories for any loose pulleys or bolts?
Old 06-27-16, 01:58 PM
F_Throttle
F_Throttle's Avatar
The tech had it for a week, checked all the pulleys and found nothing. During my ELF recall they overfilled my coolant and it sprayed everywhere so i thought it was contamination but the belts look clean.
Its odd that this comes on after I run the car in Manual mode (****ing at 5k). It comes on more during hot days (regardless of A/C on/off).
Old 02-09-17, 04:56 PM
F_Throttle
F_Throttle's Avatar
Thumbs up
Bump for you guys... I took it to another Lexus and they found the problem: Pulley Tensioner.
The following 2 users liked this post by F_Throttle:
kzlflash (02-10-17), supersonic (02-09-17)
Old 02-09-17, 06:35 PM
isfvss
isfvss's Avatar
That would have been the logical thing to do first take the serpentine belt off and listen, glad you got it fixed..
Old 02-09-17, 10:11 PM
supersonic
supersonic's Avatar
nice catch. will know what to follow for next time.
Old 02-10-17, 07:21 AM
kzlflash
kzlflash's Avatar
Did you ever take a video of the problem? Curious how it sounded.
Old 02-10-17, 07:47 AM
idoke1
idoke1's Avatar
^^The video link works.....at least for me.
hades281
03-14-18 10:17 PM
MHB1535
RC F (2015-present)
15
08-05-16 01:26 PM
ghoffner
RC F (2015-present)
12-03-15 12:47 PM
Vadim540i
Performance & Maintenance
08-30-13 07:29 PM
Metlupass2
07-24-07 10:45 PM
Quick Reply: Vacuum leak sound at 1500rpm
