Question about wheel fitment
front: 20x9 32mm offset with 235/35 tires
rear: 20x10.5 45mm offset with 275/30 tires
Im pretty new to the aftermarket wheel game and do not know a whole lot about offsets and fitment. I have a 2011 Isf and my question is, would this setup work with my car. Im basically looking to slap them on with the most minimum of modifications and have the least complications while driving. Your suggestions are much appreciated
Rich
Rich
Are these Vossen wheels? Just curious as this is close to my set up and if so I will tell you that they will recommend a 285/25/20 on the back with the 10.5 wheel so you don't rub and not sure about the +32 on the front as I went +38 with a 245/30/20 and I have zero rubbing issues...here is what my setup looks like...hope this helps
Few pointers.
235/35/20
275/30/20 will fit just fine without issues your problems comes
With the following:
Once you lower your front will rub(fender liner) as the car bounces, your rear fender will have to be rolled.
Look at mines I'm super slammed mines only rub at front at tad I had shaved n made a few adjustments to minimize rubbing but it is still there to some
Degree.
245/30/20 275/30/30 opted to not do 35 sidewall at front since I was going really low.
235/35/20
With the following:
Degree.
Few pointers.
235/35/20
With the following:
Degree.
235/35/20
With the following:
Degree.
