Feel Like Pedal Dancing
Here you go:
1. Start car, keep holding the brake pedal down.
2. Tap on the parking brake 2 times, continue to depress it on the second tap (the brake icon on the dash should flash each time, you don't actually have to engage the brake).
3. Pump the brake pedal 2 times, continue to depress it on the second pump.
4. Repeat steps 2 and 3 until you see the traction control light turn on.
So basically brake pump, brake pump and hold, parking brake tap, parking brake tap and hold, and so on.
The pedal dance turns off the "nannies" on the car until you shut it off. Holding down the traction control button will only disable the traction control but you will retain the eLSD. I believe it was posted somewhere here not too long ago.
Incorrect.
Press the button and it turns off Traction Control. Hold it down and it turns off Stability Control as well. The ELSD function remains active. The pedal dance is the only thing that turns off the ELSD and leaves the ISF a true one-wheel wonder (and why would you want this unless you hate your tires). There is a discussion regarding this in the thread below:
https://www.clublexus.com/forums/is-...results-3.html
Incorrect.
Tech Info Resource
You can spin one wheel from stop, but over 15 mph you can't. The ELSD works just fine and in some situations works better than the Torsen the factory put in the car in '10. Turning off the ELSD at the drag strip would be a big mistake if you lost traction on one wheel after the 60' mark. You'd be doing a lot of quick correcting to keep going straight.
