2011 ISF Audio Wiring Diagram
https://www.clublexus.com/forums/is-...-pictures.html
Check this thread out. It'll tell you which wires to tap from the stock amp
Bump for updates. Got the diagram going to be doing the install this weekend. Any help on wehre to find the pre amp output of the head unit would be greatly appreciated.
Tech Info Resource
It was only about 3 weeks ago that i downloaded them. The only issue I have is if there's a difference between an 08 and an 09 or 10 etc when it comes to the audio wiring diagrams.. I have an 08 so i downloaded all the 08 diagrams/repair documents obviously. Theres only about 45 wiring documents for the F, I should have downloaded them for all the years so we could compare to see any changes...
Bought a sub/amp combo and am going to install this weekend. Anyone still have electrical diagrams for an 11 ISF or whatever is applicable?
Going to use the internal LOC and wire it straight to the factory subwoofer signal. Haven't heard there's much benefit to using a LC2i vs the inegrated ones and that the accubass was more sporadic than anything.
Yeah I had to use a few different threads to piece all the information together. Would be nice to just have access to the electrical diagrams. Going to see if I can buy a book or something like I have for past vehicles.
The infamous pink remote wire was only a 5v signal so ended up just using the 12v acc plug in from the center console.
bazzle01 (03-12-17)
