Offset Guru's Need Opinion
Old 10-05-10, 09:45 PM
corkycal
corkycal's Avatar
Default Offset Guru's Need Opinion
Offset Guru's can this work on an IS-F with using coilovers and shaving the fenders? Not running excessive camber but some.
20x9.5 offset +36 with 235/35 (Fronts)
20x11 offset +45 with 275/30 (Rears)
Old 10-05-10, 10:20 PM
primecut
primecut's Avatar
Hmm.. IMO with that setup you'll likely need a lot camber and slam it to get the tuck, otherwise you'll be jamming into the fenders. It's a pretty good stretch too. Try it out and you can be the first hellaflush F.. he he. Might be a wasting the car's performance though.
Old 10-06-10, 04:47 AM
Gymkata
Gymkata's Avatar
I'm no guru, but from everything I have read and seen, those rim widths and offsets would rub horribly even with shaving unless you went with extreme camber. Also, why would you ever want to run tires that narrow on rims that wide?
Old 10-06-10, 09:53 AM
T-Rex06
Ho Motorsports
T-Rex06's Avatar
Even with stretched tires and shaved quarter panels, you'll have a hard time fitting those widths and offsets in the rear. I currently have 20x10 +40 offset with 265/30/20. The tires barely clear the quarter panels. Hope that helps. The fronts should be fine.
Terrance
corkycal
corkycal's Avatar
Maybe it's a bit too extreme to fit 9.5 up front but somehow I think 11's in the rear may be achieved??
how about?
20x9 +36 Fronts 245/30
20x10.5 +45 Rear 285/25
Old 10-06-10, 09:57 AM
corkycal
corkycal's Avatar
Primecut, what are the specs on your F?
Old 10-06-10, 10:00 AM
corkycal
corkycal's Avatar
Terrance
Hi Terrance,
So with 275/30 or 285/25, it will rub with the rear shaved?
Old 10-06-10, 10:07 AM
T-Rex06
Ho Motorsports
T-Rex06's Avatar
11" width in the rear can be achieved with the offset around +55mm. My previous set was 9.5" in the front with +36 offset and I had no issues with 245/30/20.
You will have zero problem in the front with +36 offset and 245/30 tires. The rear should be fine also, however, I have my concerns with 25mm profile tires. A few members are using that set up in the rear and seem to have no issues.
Another thing to consider is the brand of tires you use. Toyo T1R tends to have skinnier side walls compared to other brands with the same spec. So make sure you do some research on the tires also.
Terrance
Old 10-06-10, 10:11 AM
T-Rex06
Ho Motorsports
T-Rex06's Avatar
Originally Posted by corkycal
Hi Terrance,
I'd go with 275/30. It's just a personal preference. Either one is fine. Like I mentioned earlier, Toyo T1R will give you better clearance because of the way the sidewalls are built.
Terrance
Old 10-06-10, 10:16 AM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
^ This guy knows what works & what doesn't!!!!
So be sure to take his advice FULLY..
BTW - What kind of wheels are you looking at??
Besides clearing fenders and getting the widest strecth or contact patch, you also have to clear the Brake Calipers...
Joe Z
Old 10-06-10, 10:20 AM
corkycal
corkycal's Avatar
Terrance
Terrance,
Thanks for confirming that 20x9.5 +36 will work in the front. Back to the drawing board for the rears.
JoeZ, yes, I know it needs to clear BBK.
Any other inputs will be greatly appreciated. I love CL for this reason.
Old 10-06-10, 01:51 PM
primecut
primecut's Avatar
Yea like Terrance said, 20x10.5 +45 Rear 285/25 would work fine. I'm running 10.5 +43 on 275/30.
Old 10-06-10, 02:05 PM
HEWITT
HEWITT's Avatar
I am running 20x11 with +50 and 285/25/20. Your going to have to shave your fenders and even then, its still going to be real close.
Old 10-10-10, 09:19 AM
FIGS
The Maker
FIGS's Avatar
The other factor is how low you want to be. This is going to have a significant impact on clearance. Also the spring rate will determine how deep you go into the travel. Not sure how people are getting away with a 10.5 +45 without fender modifications. That seems pretty aggressive to me.
Do you mind pulling and trimming the fenders for fitments?
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 10-10-10, 03:48 PM
trackdood
trackdood's Avatar
I have 285s on a 40 offset front and rear. Get ready to cut and pull everything..
Lveyolfe
03-06-17 09:56 PM
valeoray
09-19-14 09:07 PM
bentleymp2
11-21-12 07:54 AM
Socal300sd
Wheels, Tires & Brakes Forum
07-20-09 04:38 PM
Carisma FR
11-05-04 12:43 PM
Quick Reply: Offset Guru's Need Opinion
