IS C Discussion about the convertible IS C model
What's compatible?
Old 05-30-12, 06:16 AM
BigTopGT
BigTopGT's Avatar
Default What's compatible?
Hi Guys,
I think I've found a source for some parts I need, but I'm not too sure what'll fit and what won't.
Does anyone know, off hand, what years have interchangeable interiors with a 2010 ISC? (350, if it matters)
I need to know if the following pieces are interchangeable from an older coupe to a newer convertible.
Center console shifter bezel (the piece whe the shifter pokes through.
Door pulls (waterfall interior pieces you grab to shut the door from inside
Speedo gauge bezel
Arm rest and arm rest base ring
Thanks!!
Alan
Old 05-30-12, 01:35 PM
mikes rx
I use "..." ....... a lot
mikes rx's Avatar
All of these are IIRC based on the sedan I had prior, but....
Yes
The silver grab handle itself maybe, but the door panel itself is a no....the doors are bigger)
Speedo gauge bezel
Don't know what you mean by the bezel.....I believe the cluster housing and all is the same size, however the gauges themselves are different
Yes I believe the arm rest is the same....don't know what you mean by base ring
Old 05-30-12, 04:41 PM
BigTopGT
BigTopGT's Avatar
Thanks.
The speedo cluster bezel is the ouster-most piece. If you look at your gauges on the dash, you can see there's a plastic ring just outside the glass that almost appears to hold the glass in place.
The armrest base ring is the trim pieces directly under the armrest. If I'm not mistaken, it's the part the armrest physically closes against.
The door pull handle seems to be the hardest pieces to come by.
Old 05-31-12, 01:36 AM
ISCjonny
ISCjonny's Avatar
Haha.. Hi Alan,
I'm pretty sure everything is interchangeable except for the driver and passenger window switch plates. 06-08 is different for sure.. i know they changed in 09+.. but i dont know if it is different between the 4door and vert.
Old 06-01-12, 05:52 AM
mikes rx
mikes rx's Avatar
Originally Posted by BigTopGT
Thanks.
If that's the case, then yes I think the speedo bezel is the same in sedan vs vert. And I think the armrest ring/mount you're referring to is the same as well.
I think the silver "garnish" part of the pull handle is the same....but the door panel itself definitely is not.
Originally Posted by ISCjonny
Haha.. Hi Alan,
The switches may fit...I'm honestly not sure. I do know though that the ISC doesn't have auto rear windows like the sedans do (at least not on my 2010), so the switches themselves are different. IIRC, the sedan window plate states "all auto" with no wording on the switch.....the vert has "auto" written on the actual front switches, but not the back window switches.
C'mon Jonny, you're supposed to remember this stuff from your IS350Jonny days
Swacer
NX - 1st Gen (2015-2021)
07-06-15 06:55 AM
G000BER
04-06-12 04:55 PM
Flufferiou
08-16-05 01:33 PM
mikeloc24
SC400 / 300 Classifieds
03-31-05 11:36 AM
GSXRAWD
GS - 1st Gen (1993-1997)
02-11-04 02:05 PM
Quick Reply: What's compatible?
