Moisture in Headlight
Received 1,738 Likes
There is a service bulletin out that may address your issue:
https://www.clublexus.com/forums/is-...ml#post9182367
Check to see if your housing is cracked as described in noted TSB. You can Google search to see where to locate the actual TSB so you can read.
Check the headlight mounting tab on top first.
No it doesn't but I noticed the moisture as I was drying my car after cleaning it yesterday. My hood was misaligned in an accident almost a year ago but it got fixed. I noticed yesterday that it still is slightly misaligned so I thought that might be a factor. I just checked my headlights and found two really small hairline cracks but I'm not sure if it is enough to let moisture slip in.
