TPMS help: System won't reset/initialize
Old 02-23-17, 04:37 PM
RotorPilot
RotorPilot's Avatar
Default TPMS help: System won't reset/initialize
Hey guys, I had 3 wheels refinished by an independent wheel shop after the valet and wife had some curb mishaps. Upon picking up the car, the TPMS light was on solid but figured I'd give it a few days to relearn. After a week and no luck, I took the car back to the wheel shop and they tried lowering the pressure and resetting it, but that's all they knew and they didn't have an OBD tool. Same sensors are on the wheels and I don't believe they were removed from the wheels. I can tell because one has over spray on the valve stem.
Once I turn the Ignition to "On," the light blinks fast for 1 minute then goes solid. I've tried everything and can't get it to "blink slowly 3 times" and reset. I'll hold down the Set button as soon as the Ignition turns on, I've waited for it to go solid, tried it with and without the ebrake, tried it while running, nothing seems to matter.
I've lowered the psi in all 5 tires to 30
Lowered 4 tires to 30, kept spare at 60
Raised 4 tires to 36, tried spare at 36 and 60
2014 IS350 F Sport
Any help is appreciated!
Old 02-23-17, 06:19 PM
manchild
manchild's Avatar
you may have to register the sensors again... you will need a cheapo OBDII cable and TIS Techstream. If you are still under warranty just take it to the stealership. Otherwise if you are handy with a laptop re-add the tpms sensors yourself.
Old 02-24-17, 06:23 PM
RotorPilot
RotorPilot's Avatar
The car is still under warranty but I was hoping to avoid the dealership. Thanks!
Old 02-24-17, 06:55 PM
Ray20213
Ray20213's Avatar
Default Solution ...
Just go to any America's tire company they have the sensor tool that they can plug-in to your OBD11 sensor and reboot it for u they did it to mine when I got my wheels and it fixed it no problem
Old 02-25-17, 06:21 PM
Answer
Answer's Avatar
If you have the same sensors and it was working before, they may have broken a sensor... I will act this way if a sensor is missing.
Old 02-26-17, 12:38 PM
Sasnuke
Sasnuke's Avatar
Received 1,732 Likes on 1,368 Posts
I hate to say it, but I think Answer is correct...one of the sensors may have been damaged.
You will need to check and see if any codes are stored for the TPMS system. Ray20213's suggestion to take it to a shop with the tool is your best bet at this point.
Old 02-28-17, 08:00 PM
RotorPilot
RotorPilot's Avatar
I think you guys are right and they probably broke one. I'll stop by Discount Tire next week if possible. Thanks
Old 04-07-17, 11:57 PM
LexoticJ
LexoticJ's Avatar
Any further update on this. I'm currently have the same issue. I've been to discount tire and put on new sensor.
GXOutlaw
GX - 1st Gen (2004-2009)
18
06-19-19 07:52 PM
Steve04RX
07-27-18 12:21 PM
IamLexus
07-16-18 07:26 PM
gmoney94
01-30-18 07:01 PM
Quick Reply: TPMS help: System won't reset/initialize
