Has anyone updated their Navigation SD Card?
I've done mine. It took quite a while to update while I was driving around. First drive home from Lexus was about 20 minutes & it was still updating, couple of short drives after that it was still updating. Then all of a sudden done. It was getting to the stage I didn't think it would work unless I went for a long drive.
When i got my 2014 Lexus is 250 i check on lexus's website and it stated there were no system updates. However after multiple crashes where the navigation screen would flash blue for about 5 seconds and then reboot itself, i took it into the dealership and they updated it for me. I think your best bet would to probably ask the dealership to check for updates since they usually do it at no cost.
I'm having the same issue. I can't get passed "checking data -- contact your dealer" even after disconnecting the battery and getting the screen that shows the SD card is being read and even after updating the system software. I have run out of things to try.
There is not a GPS on the SD card. The SD card only has the graphical maps and the GPS tied to the system and overlays your exact location on those graphical maps. So if you could get it to work without the maps it would be a blank screen with your position.
Mine says it is checking data but if you do anything to move away from the screen it gives that error message.
On Nov. 18, 2017, I purchased a 2015 L/Certified ES350 at a Lexus dealer. I was told by the salesman that it had the most recent navigation update. After I got home I was familiarizing myself with the system and see that the Navigation version is a 2014 version.
-- The version in my 2015 ES350 is: "Map Version: 21-34-17 [2014-06-1]". That looks like a 2014 version to me.
BTW: The URLs posted previously to http://www.lexusnavigation.com/ just show a website under construction with nothing to see. I assume it was working earlier and will be at some future time. Most decent webmasters give a time frame for when their websites will be out of service.
I could not see what version I need due to http://www.lexusnavigation.com/
not being in service.
Question: Are L/Certified vehicles supposed to have the latest Nav update when sold??
Going to call and ask what the heck!
EDIT: Am being told to 'give it a few hours' to process. Will see what happens.
CaptDuck (01-08-18)
eddie420 or anyone, Can you tell us how much the GPS update cost? Cost of the SD card? Cost of the dealer installation?.
Also, is your system showing that the version has been updated, or is it still showing the old version?
Did you get to keep the SD card? (I assume it is in the slot in your vehicle).
Thanks
Thanks
Thanks
Thanks
