My First Fiberglass Sub-woofer Box
I have not been the most active member in CL in the past few years... In my 07 IS I did a 10" JL W7 in a ported box
(https://www.clublexus.com/forums/is-...spec-pics.html)
... It was too much bass, not as enjoyable. This time I decided to scale back to a 10" JL W6 in a sealed box but I still need my trunk space so I decided to go Fiberglass: Below are a few pictures along the way..
Fiberglass Prep
After 2 layers of glass has dried its ready to be removed.
put it back in the car and draw the shape you want it to be cut.
Cut with tool of choice... I used an angle grinder.
Hot Glue your speaker Ring, It will be reinforced with fiberglass in the near future.
Cover the front of the box with felt, hot glue on the back of the fiber. Again it will be reinforced with fiberglass. IMPORTANT MAKE SURE IT FITS AND THE TRUNK CLOSES.
Test fit after the resin dries if it doesn't fit or hits the trunk latch.... start over.
ADD ABOUT 6 layers of fiberglass, I found this nice netting that is made for fiberglass resin so I alternated between the traditional fiberglass sheets and the new fiber-netting.
According to JL Website I need 15.57 L of volume, with the packing peanut method I ended up with about 15 L I will add poly fill to make up the 1/2 liter I shorted the sub.
Carpet the box with carpet of your choice. I used Loctite spray glue and it took some time to get it right with all of the curves.
Add a speaker terminal, Luckily I had the JL box that was made for the sub so just borrowed the terminal from that.
Add the sub. I also added the grill for protection.
Final resting place. The carpet was much darker in the store.
Quite a bit of bump for the minimal space.
Again according to JL Spec I am 1/2 a L short of internal volume, I added poly fill and honestly the sub sounds great, much more pop then when I had the ported W7.
If anyone has any questions feel free to ask, this was a learning experience for me and kind of fun took about 2 weeks as it is not a fast process.
I am using the new JL RD 500/1 Amp and couldn't be happier with it, all wires/amp is hidden under the box. I will do a quick write up in a few days if anyone is interested.
Fiberglass Prep
Please make me one.
So I designed the box so that I could still use the factory hooks for the cargo net etc. It just so happens they hold the box super tight, It is not going anywhere we will see how well it fits with the cargo mat once I put it back in.
- I will show my amps location and where I hooked the wires to in a few days, I am waiting for the JL bass control **** to come, should be early next week. I will do a separate write up as I have had a few questions while hooking up the ground and remote wire.
Nice work. I wonder why you decided on driver side quarter panel instead of passenger side? I also did a fiberglass enclosure but on the passenger side because I wanted the trunk mat to be usable instead of enclosure sitting on top of it. There is nice cutout on the trunk mat on passenger side.
You should've also probably with for straight black carpet to cover it to match the stock black trunk liner better
It was a tough decision to use the drivers side, but ultimately there were two reasons.
1. There was a slot for my first aid kit on the passenger side.
2. There is a carpet cut out where I could run my speaker wire right to the box.
It ended up working fine with the trunk mat, and I do agree I wish I would have used a darker material to cover the box.
Still fits great with trunk mat.
Perfect speaker wire cut out
I will do a quick amp and wire thread separately to answer the other questions above.
gapxguy
01-07-07 05:35 PM
