Lexus IS Sway Bar
Old 05-16-16, 09:22 AM
kyoungjook
kyoungjook's Avatar
Originally Posted by Nigel-JDMParts
What endlinks is available?
Might as well upgrade to aftermarket.
What are the options for aftermarket end links or even sway bars that fit a 3rd Gen IS350?
Old 05-17-16, 02:16 AM
Nigel-JDMParts
Nigel-JDMParts's Avatar
We are trying to find out…..
Hopefully, we will have update shortly.
Old 05-17-16, 05:59 PM
gpxluke
Former Sponsor
gpxluke's Avatar
I checked RC350 endlink part# is the same as the 3IS
Old 05-17-16, 06:19 PM
kyoungjook
kyoungjook's Avatar
So, seems like just upgrading the stock IS350 rear sway bar to the stock RC350 rear sway bar, even using stock endlinks, makes a difference? Anyone know the part number the stock RC350 rear sway bar?
Also, I noticed that webra had an IS300h - is the rear sway bar from that car the same as the one in the IS350?
Old 05-18-16, 09:26 PM
gpxluke
Former Sponsor
gpxluke's Avatar
This is the RC350 rear sway bar part# - 48805-24040. I believe one of the forum member put that on and it's a direct fit. It's 3mm thicker than the IS350 rear sway bar.
LexoticJ (02-03-21)
Old 05-18-16, 09:33 PM
Nigel-JDMParts
Yes, that's correct!
And stay tune for now.
We might have some good news for the 3rd GEN IS soon.
Front and Rear sway bar
Old 05-18-16, 09:57 PM
forum429
forum429's Avatar
Any one know if the RC350 AWD rear sway bar will fit a IS350 AWD?
Thanks
Old 05-19-16, 03:58 AM
Nigel-JDMParts
Thanks
Order one from dealership and try
Old 05-19-16, 04:51 PM
kyoungjook
kyoungjook's Avatar
Thanks!
So, looks like that part is only about $140 - for that price, seems like a no brainer.
To confirm, everything else can just be re-used from the existing stock setup it seems like?
Old 09-11-16, 04:53 PM
otakusan
otakusan's Avatar
Did anyone ever attempted the RC350 AWD rear sway bar on the IS350 AWD yet?
Old 10-04-16, 09:55 AM
E46CT
E46CT's Avatar
Received 2,211 Likes on 1,655 Posts
I'll be doing a full write up, review, and pics this week. Just got mine in the mail. We'll see if it installs!
The bar I received is from the Lexus RC RWD. There is no difference according to Lexus from the RC200t and RC350 F-Sport and non F-Sport variants. All RC200t and RC350 RWD rear sway bars are the same according to them.
The bushing says "19.1mm" on it so I'm guessing that's the diameter. Since it's 3mm bigger as the OP says here, the stock 3IS F Sport sway bar is 16.1mm. I'll confirm when I get it off the car.
The IS does feel nose heavy so this should make a nice difference.
LexoticJ (02-03-21)
Old 10-04-16, 10:54 PM
E46CT
E46CT's Avatar
OK for anyone that installed the 3IS rear sway bar how the heck did you do it? The nuts are next to impossible to get to. Looks like the subframe needs to be lowered a few inches.
The only thing I can think of is a specialty socket with a hex head on top. Then use a wrench on that.
LexoticJ (02-03-21)
Old 10-05-16, 06:39 AM
otakusan
otakusan's Avatar
according to the service manual, you have to remove the subframe
(sorry my PDF uploads are for AWD model... RWD model may be different)
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
LexoticJ (02-03-21)
Old 10-05-16, 07:38 AM
E46CT
E46CT's Avatar
^Really appreciate that. That seems like a TON of work to replace a sway bar. I think I'll return it.
Old 10-05-16, 07:41 AM
otakusan
otakusan's Avatar
Dropping rear subframe is actually not that bad ^^; if you have a couple of jacks. Or you can see what a shop wants to do it for you.
LexoticJ (02-03-21)
Quick Reply: Lexus IS Sway Bar
