Break Caliper Painted?
#33
Spray clean the grease, oil, dirt off. Brush clean to get clean to the surface. Wipe down with clean rag. I done 4 coats of primer. 20 minutes between each coat. 6 base coats of red. 1 hour between each coat because the sun went down. Let it dry over night. Laid on my decal and did 6 coats of clear coat. 30 minutes between each coat. Let it dry completely before peeling tape from edges. Although it might feel dry on the outside. The inside layers may still be wet. Paint can lift off. I let everything dry over
night once again before actually driving it on the road to be safe.
