Spacer questions
Spacer questions
Hello, I am about to order spacers
20mm Front
15mm Rear
Would my camber change?
Im looking into getting H&R spacers. I have read that people have had experience with the steering wheel being shaky after putting on spacers, is that true?
20mm Front
15mm Rear
the video does a good job at explaining spacer attributes.
keep in mind, the video still holds true when you get a wheel with more aggressive offsets than stock.
for the 3is f-sport, stock wheels are 18x8+45 and 18x8.5+50
if you got an aftermarket wheel with 18x8+25 and 18x8.5+30 wheels, the effect would be the same if you had put on 20mm spacers on the stock wheels
I actually just edited my original post, I meant to say 20 front and 15 rear. Just because my front wheels are not as close to my fender as my back wheels are stock.
nah everything was stock in that pic. Looks like alot of camber for a car that doesnt even have camber control huh? I just got spc camber kit that im installing tomorrow since my new bbs wheels are rubbing like a **** in the rear cus of the offset. Needs some negative camber.
What Chris said^^^^ you will still rub at full turn. I have a LS430 and ordered 25 rear 15 front and even with all of the space stock height and wheels I should rub plastics slightly at full turn. You certainly have less room to work with.
20 rear 15 front on your model even 25 rear 15 front looks good on stock wheels. Lots of examples if you jump into the vendor spacer threads.
SloGS400
02-06-08 05:20 PM
