No Lexus dealership close, suggestions to oil change?
Old 01-18-16, 09:45 PM
jeeper2269
jeeper2269's Avatar
Default No Lexus dealership close, suggestions to oil change?
I live in central Oregon and there are only two Lexus dealerships. One in Eugene, one in Portland.
If I cannot drive to either, what is your suggestion?0
Old 01-18-16, 10:10 PM
tea
tea's Avatar
do it yourself
Old 01-18-16, 10:34 PM
davyjordi
davyjordi's Avatar
toyota dealership.
Old 01-18-16, 11:36 PM
jeeper2269
jeeper2269's Avatar
I can't seem to find the filter.
Buddy of mine has a BMW and has a suction device to pull the old oil out.
Wondering if this would be better.
Old 01-19-16, 01:24 AM
isfdude
isfdude's Avatar
Make sure you change your filter as you can cause problems to the motor. The filter is located on the bottom above the plastic cover near the front of the vehicle there should be either 1 or 3 10mm bolts to take off and it's right above the little cover. This is not a regular metal housing filter what you're going to replace is just a synthetic filter itself and O-ring around the housing. This is not a regular metal housing filter what you're going to replace is just a synthetic filter itself and O-ring around the housing. Make sure you use fresh oil around the new ordering and the housing so you don't damage the O-ring. You have to twist off the aluminum oil filter cover counterclockwise to get it off.
This is what you need to look for.
Old 01-19-16, 12:22 PM
theoryguy
theoryguy's Avatar
You can do it yourself or just take it to a local shop. In terms of oil Mobil One is pretty standard
Old 01-19-16, 12:38 PM
dfwjohnd
dfwjohnd's Avatar
Jeeper2269's house.
Old 01-19-16, 07:01 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Go to Toyota. Best alternative I have used on my cars over the years.
Old 01-19-16, 07:08 PM
CrackerJac
CrackerJac's Avatar
I go to Mitchem Tire but have a long-time friend who works there. $16 and I bring my own oil/filter.
Old 01-19-16, 09:19 PM
isfdude
isfdude's Avatar
I don't let anyone touch my cars. I've noticed that when I started working on my cars I have never had any problem with any of them. No paid mechanic is going to take the time to make sure everything is adjusted perfectly like you would.
Old 01-21-16, 10:13 PM
MWIS350
MWIS350's Avatar
If changing oil yourself. Make sure you drain motor oil by the oil filter. And not the transmission oil. That's in middle of the car.
Old 01-23-16, 08:45 PM
isfdude
isfdude's Avatar
Oh yes I know a hand full of people that did that lol
Old 01-25-16, 06:17 AM
MD TEACH GS300
MD TEACH GS300's Avatar
If DIY, do not forget to coat the oil filter gasket with a light coat of (a little on your finger) some fresh oil before installing. That will ensure a snug seal.
Old 01-25-16, 09:04 AM
MWIS350
MWIS350's Avatar
I also did that first time changing
Old 01-26-16, 06:38 PM
shirosan
shirosan's Avatar
Originally Posted by davyjordi
toyota dealership.
+1 on the Toyota dealership. If you are trying to stay within a dealership's (Lexus) point of view, you can do Toyota. Otherwise, most, if not all, Lexus dealership are willing to drive out to your location to pick up the car (drive it to their service center) and bring it back. I've experienced this in two different states (Texas and Iowa).
Hope this helps too.
sam430
06-19-15 09:22 PM
EDness
10-15-13 12:17 PM
yeehawbob
Hybrid Technology
17
05-20-13 08:47 PM
MotoX
10-28-08 07:53 AM
lexian
RX - 1st Gen (1999-2003)
07-29-02 09:31 AM
Quick Reply: No Lexus dealership close, suggestions to oil change?
