Audio signal for DSP question
Hey guys, I'm hoping somebody can answer this. I'm looking at getting an lexus is350 f sport with ML and was wondering if anybody knows how good the HU is as the source going to an aftermarket DSP like the mosconi or helix. I'm hoping the signal to the front channels are full range and flat so I can use them as the inputs. Is there any processing going on in the HU that would cause problems or is it all being done in the amplifier?
thanks.
thanks.
thanks.
thanks.
the front channels aren't full range in signal. For a true full range signal, I would recommend a channel summing device such as LC6i, feed it into a DSP, and then feed it into an amp (or maybe feed it into an amp first, then into a DSP).
Our rear door speakers are labeled as "full-range" drivers, but in reality they fade way too much below 100hz. You could attempt to feel into the 2 channel speaker level input signals that sees full-range, but you may or may not get a strong enough signal to get quality sound.
Most DSP's like the Helix can do channel summing so there's no need for a convertor like the Audiocontrol. I was just curious as to whether anybody had verified the signal output from the head unit before the amp. Some cars employ the crossovers and any processing in an external amp (I'm hoping that is the case) Other vehicles mess with the audio signal in the HU itself.
Cool. I'll be interested to know how that works out. A good audio shop will have access to an RTA that they'll be able to hookup to the output channels on the head unit to measure freq range and how flat the signal it is.
They will be tuning with oscilloscope & RTA. These guys are number one in Australia so I'm sure they will work it all out.
Why not just get the Line Level Audio full range that is passing Between the stereo to the amplifier?
Granted Volume **** from stereo will not probably not work anymore due to it being controls by BUS signal sent to amplifier but most aftermarket DSP have own **** anyways.
This way no worry of factory crossovers, etc.
See page 7-8 of wiring schematics to see what I mean
https://drive.google.com/file/d/0B-a...ew?usp=sharing
My system has been finished for a couple of weeks now.
The line between the headunit & amp is digital so can't be tapped into. My tuner has mixed various outputs from the OEM amp to get the desired feed for the PS-8 processor to send to the amps. He also had to mix in some front middle as the navigation sound comes from here.
I can post up a pic of my PS-8 mixer GUI but probably only any good if someones runs a PS-8.
I'm extremely happy with the system, the only thing that lets the ML down is no lossless format USB inputs. I've been playing with a USB hard drive running AAC files which is the least lossy. So far I can now see the files on the headunit but they won't play. It seems the sampling rate & bit rates are pretty fussy. I have lossless music on my iPhone but the dreaded ipod error is hindering using that. Might have to buy a dedicated iPod or stick a media player straight into the processor.
So I ended up picking up a 14' IS350 F-sport without ML. Does anybody know what wires should be used as the inputs for an after market DSP. From my bit of research it appears that I need to use the front L+R channels after the factory amp in order to retain the factory HU controls. Can anyone confirm if this is the case or not? Again this is a non mark levinson system if it matters.
This vehicle is pretty finicky. I have an audiocontrol dm-810, two 4 channel amps and a 2000 watt sub amp. I replaced every speaker except the factory sub. I just removed that and use it as a port. It’s been running nice since August 2019. I used all the factory amp outputs and summed channels to selected outputs and everything works fine. I also have a mechman 240 amp alternator and a Xs Power d3400 battery. I installed all myself and it took A WHILE!!! If you need Pointers I’m here.
djsohott
04-14-14 08:27 PM
