Adjust number of clicks for directional?
Old 06-30-15, 03:50 AM
sc02492
sc02492's Avatar
Default Adjust number of clicks for directional?
I was wondering if anyone knows whether it's possible to increase the number of clicks for the "temporary" directional (it's currently only 3 clicks, which isn't very long). I'm referring to when you push the directional lever only a small amount and then release (as opposed to engaging it completely)....
Old 06-30-15, 04:37 AM
osh3is350f
osh3is350f's Avatar
There's a way I remember reading a thread on it a while back. Try searching
Old 06-30-15, 04:49 AM
swfla
swfla's Avatar
Received 1,209 Likes on 956 Posts
Lexus personal preferences offers that choice on some years and models (you'll have to do a search). Either got to the dealer (possible charge) or buy one of the software apps and OBD2 adapter to do it yourself.
Old 06-30-15, 04:56 AM
doodlebug
doodlebug's Avatar
https://www.clublexus.com/forums/is-...s-to-more.html
Old 06-30-15, 08:55 AM
sc02492
sc02492's Avatar
Thank you! I appreciate the link- will try this later today.
Old 06-30-15, 09:50 AM
LeapFrog
LeapFrog's Avatar
Default Factory Instructions
https://www.clublexus.com/forums/is-...ml#post9065561
Old 06-30-15, 04:13 PM
sc02492
sc02492's Avatar
I changed the flashes to 5 instead of 3 on my 2015 IS 350 F sport, so the procedure worked fine. Thanks again for pointing me in the right direction.
Now if I could only figure out how to configure this so that pressing the stalk in the SAME direction cancels the turn signal, which is what I am used to in my previous cars. I tried doing a search but couldn't find anything about this.
Old 06-30-15, 04:59 PM
Rebirthing
Rebirthing's Avatar
5 blinks is perfect for changing lanes.
I don't think you can configure the stalk to function that way. (Correct me if I'm wrong) It's always been the opposite direction to cancel.
Old 06-30-15, 05:49 PM
My0gr81
My0gr81's Avatar
Step 7 in PDF attachment on the factory direction thread linked by leapfrog above will have that instruction.
Old 07-01-15, 12:39 AM
sc02492
sc02492's Avatar
Perhaps I'm looking at the wrong file, but step 7 in the factory pdf that Leapfrog provided only appears to refer to changing the number of flashes, which I've already done. I'm interested in changing the way that the stalk moves to cancel the directional. I would like to move the stalk in the -same- direction as the directional to cancel it, not the opposite direction (which is the way it is configured now). Am I looking in the wrong place for the instructions/
Old 07-01-15, 03:55 AM
swfla
swfla's Avatar
It can't be done. What if someone wasn't able to change lanes the first try and wanted to add more flashes by moving the stalk again? Your way, it couldn't be done
Old 07-01-15, 04:13 AM
LeapFrog
LeapFrog's Avatar
Swfla is correct; you can't enable BOTH the blink-to-change-lanes feature AND the cancel-turn-signals-by-moving-stalk-in-same-direction feature. You have to pick one or the other - see Step (c)(1) on the 1st page of the .pdf provided.
Old 07-01-15, 07:35 AM
sc02492
sc02492's Avatar
This clears it up for me- thanks again. I think that I like the ability to cancel the turn signals by moving the stalk in the same direction, more than I like the "blink to change lanes" feature. I will experiment with this, now that I know how to change it, and can always change it back....
ruger
05-07-16 08:33 AM
alee350
Performance
09-10-11 07:26 AM
troy1987
04-30-09 05:40 PM
lostgs400
12-27-07 08:07 PM
performula
SC- 1st Gen (1992-2000)
08-24-03 05:54 PM
Quick Reply: Adjust number of clicks for directional?
