DIY - LED Puddle Lights? Anyone Done This?
Old 12-04-13, 01:37 PM
Kwik8276
Kwik8276's Avatar
Originally Posted by jhs82
Yup, that's the right procedure.
I'm trying to pull down on the tab behind the mirror but no luck ! Damn finger hurts for trying it !! Any other way ??
Old 12-04-13, 01:45 PM
splat0023
splat0023's Avatar
The mirror is just held on by 4 tabs and they just pull straight off.
Old 12-04-13, 01:48 PM
Kwik8276
Kwik8276's Avatar
So just pull forward and it should come right off ??
Old 12-04-13, 01:51 PM
Randre19
Randre19's Avatar
Originally Posted by JWadle
Does anyone have a source for LEDs for the 2014 IS350 puddle lights?
Here is an option from HID powerhouse. Its not on the website anymore, but they offer Titan RR Super White LEDs in addition to the ones in the link. Both fit the 2014 IS350 model. I purchased the TitanRR's when they were available on the website. Im sure you can call and order those specifically if thats what you want.
http://hidpowerhouse.com/2014-lexus-...-installation/
Old 12-04-13, 03:10 PM
ISISGUY
ISISGUY's Avatar
I just did this yesterday, try to get your finger in betwen one of the little tabs to loosen it a little and pull gently but firmly. You'll hear it unsnap, once one goes, the other ones will unsnap. I didn' t pull them out forward I worked the edges where the clips were until it came off. Once you do one, the other one will be easy to take off. Putting it all back was harder just because everything has to line up perfectly and sometimes it just doesn't want to.
Old 12-05-13, 12:00 PM
Kwik8276
Kwik8276's Avatar
Just wanna say thanks again for the help with the puddle lights ;-) it worked out great
Old 12-05-13, 12:15 PM
Kwik8276
Kwik8276's Avatar
I know what u meant bout lining it up bout worked out great , thanks everyone for the help ;-)
splat0023
splat0023's Avatar
Anytime. I'm glad it turned out good.
Old 12-05-13, 12:24 PM
alexlude
alexlude's Avatar
do the LED puddle lights dim on and off or do they just turn on / off?
Old 12-05-13, 12:37 PM
Kwik8276
Kwik8276's Avatar
When I put them in , they dimmed in and out for me , y ? Are others just shutting on and off ?? That's not cool ;-)
Old 12-05-13, 01:56 PM
alexlude
alexlude's Avatar
not sure.. i just read that they turn on/off in the 4GS DIY thread . Do they illuminate as much as the stock bulbs? ( know LED looks better but does it illuminate just as much?)
Old 12-05-13, 02:07 PM
Kwik8276
Kwik8276's Avatar
Yes they do !! I tested it with all the lights off in the garage and there is a big difference !! The floor seems to light up more ;-)
Old 02-23-14, 10:36 PM
SilentWish
SilentWish's Avatar
sorry to bump an old thread
should i use a flank LED so that the light points downward after the LED bulb is installed on its side?
or does the harness point the LED bulb straight down after the install?
Old 02-24-14, 04:03 PM
specONE
specONE's Avatar
This should give you an idea
https://www.clublexus.com/forums/is-...th-photos.html
Old 02-24-14, 06:17 PM
SilentWish
SilentWish's Avatar
Originally Posted by specONE
thank you so much for your reply!
i've also searched up that thread before, but was not sure of the orientation of the pic
seems like the light source should be pointing down vertical on the tip of the bulb in the 3IS instead of the bulb being installed horizontally and the light source on its side like a flank bulb?
for those who have done the mod, please verify so i can see if i already have the bulb from my 2IS or will have to purchase another one
thanks in advanced!
Quick Reply: DIY - LED Puddle Lights? Anyone Done This?
